AGM and Alternator
bobwhorn
Vessel Info: 1989 Carver Santego 3867. Repowered with Cat 3116s in 1993.
Has thanked: 3 times
AGM and Alternator
Postby bobwhorn » October 6th, 2023, 11:41 am
Thinking of going to AGM since with the current battery location there is no way to check fluid levels or top off if necessary. The existing AC charger has a AGM setting, but what about the engine driven alternator?
Bob
Re: AGM and Alternator
Postby km1125 » October 6th, 2023, 3:09 pm
The difference between AGM and a flooded battery is so insignificant it won't matter if the battery is charged via the alternator or the charger. The biggest difference is in equalization voltages and times and the alternator doesn't even perform that function. That function is important for batteries that don't get exercised regularly and starting and running the motor does precisely that.
Postby Viper » October 6th, 2023, 4:22 pm
You can address charging AGM with the alternator by adding a smart multi stage regulator. That is the best option and should be practiced more IMO, but they aren't cheap. Really comes down to your boating style though. If you're running for hours/days, a smart reg is the way to go. If you're just going around the corner all the time, it's probably not worth it.
bobwhorn
Postby bobwhorn » October 7th, 2023, 1:39 pm
I still have a Balmar external regulator somewhere. I guess I would have to get the alternators modified for an external field connection. The AC Prostar chargers do use the same settings for AGM and flooded.
Return to “Electrical”
Users browsing this forum: Google Adsense [Bot] and 30 guests
