'89 Santego, AC problem
- bobwhorn
- Vessel Info: 1989 Carver Santego 3867. Repowered with Cat 3116s in 1993.
- Has thanked: 3 times
- Contact:
Re: '89 Santego, AC problem
We'll see when I get gauges hooked up and add some Freon.
- Has thanked: 602 times
- Been thanked: 1310 times
There was a thread about that a while back I believe. It has gotten warmer as of late, water and air.
- Been thanked: 1111 times
Doesn't cost you anything but time to do this, and the you have actual data to drive your decisions going forward.
In other words, more is better in this case. I believe the minimal requirement is 200 gph / 12,000 btu however this is minimal and one must account for partial inlet filter clogs and loss of flow due to manifolds and elbows on multi unit applications. Go big.
- bobwhorn
- Contact:
I've been having to flush the line to the forward unit occasionally due to a high pressure shutdown. Now that the weather has cooled down we'll try to keep the system going as is, but planning on installing a bigger pump before next summer.
- paulr
- Vessel Info: 396 CY Aft Cabin 2001 8.1 Crusaders
- Has thanked: 54 times
- Been thanked: 32 times
Choose the appropriate topic heading, at the top you will see New Topic, open that and go from there.
