15mm PEX tubing near Jacksonville, FL
KyleR
Vessel Info: MV Verity
2002 Carver 396
Twin Cummins 6BTA 370HP
Has thanked: 143 times
Been thanked: 134 times
Postby KyleR » December 15th, 2023, 9:34 pm
Hi all,
Is there anyone in the Jacksonville, FL area that has any 15mm PEX tubing?
Our water heater bit the dust ast week - and I already got a new one along with all the fittings I need. I couldn't find a source for 15mm fittings locally so I did a big order from Defender which came in today.
Unfortunately I only got 2 ft of 15mm tubing as I thought it would be enough. However, now that I'm knee-deep in the project I really want to move some things around which requires a little more tubing than I have. I'm looking for maybe 5-10 ft at the most.
Is anyone local to the Jacksonville, FL area that has any they're willing to sell me? I can order more online but then I won't get it until next week sometime and I'd really like to finish this project up this weekend.
Thanks to anyone who might be able to help! We have access to a car so we can drive to meet you.
Kyle
MV Verity
2002 Carver 396
Been thanked: 601 times
Re: 15mm PEX tubing near Jacksonville, FL
Postby tomschauer » December 15th, 2023, 9:45 pm
Kyle, you can get John Guest Fittings to go from the old 15mm to the newer 1/2" quest pex. I personally would not try to add any 15 mm pipe.
KyleR
2002 Carver 396
Postby KyleR » December 15th, 2023, 10:49 pm
Thanks Tom - good idea! I'll look around tomorrow and see if I can find those locally.
MV Verity
2002 Carver 396
Has thanked: 598 times
Been thanked: 1281 times
Postby bud37 » December 16th, 2023, 9:33 am
KyleR wrote:Source of the post Hi all,
Kyle
Do you have west marine stores in the area ? Really any marine supply stores , yards etc will or should have that hose and fittings I would think....good luck with the project.
KyleR
2002 Carver 396
Postby KyleR » December 16th, 2023, 9:43 am
Thanks! I've called 3 marinas and two boat supplies places this morning with no luck. I did find a 10meter roll at West Marine for $66 as a last resort - although I really have no use for that much or want to pay $2/ft when I can get it at Defender for 0.79/ft - but there is something to be said for getting it now! :-D
MV Verity
2002 Carver 396
Been thanked: 1180 times
Postby Midnightsun » December 16th, 2023, 12:05 pm
The local Home Depot may have this. Read this for explanation. viewtopic.php?f=7&t=3228&p=20983&hilit=blu+lock#p20983
KyleR
2002 Carver 396
Postby KyleR » December 16th, 2023, 12:27 pm
I've tried the 1/2" stuff when I replaced our sink but it was just a tad too big for the 15mm fittings I had purchased. I like Tom's idea of just getting a 15mm to 1/2" adapter - then parts become plentiful!!
Thanks for the suggestion though!
MV Verity
2002 Carver 396
Postby Midnightsun » December 16th, 2023, 12:31 pm
The issue is some will be 1/2" and others 15mm. Today is fine you will remember what you did but after you or the next owner will be scratching their heads wondering what the heck. ;-)
The Blu-Lock stuff I pointed to IS 15mm OD although it is advertised as 1/2" tube.
