Electric Hot Water Heater Anode
Mikwallace
Vessel Info: 1998 Carver 405 AC 7.4 Horizon engines
Has thanked: 117 times
Been thanked: 23 times
Postby Mikwallace » October 26th, 2023, 10:12 pm
After seeing what the Anode in my Genny looked like, I'm wondering if my Hot water heater has an Anode? Obviously I'm not on the boat and can't look. Which brings up another subject. Do the engines have anodes also?
Guess I'm sorta thinking out loud?? Just wondering what you guys have come across with these?
Thanks!
1959 Larson 16’
1979 Caravelle 18’
:captain2:
:usa:
Been thanked: 1180 times
Re: Electric Hot Water Heater Anode
Postby Midnightsun » October 27th, 2023, 3:47 am
This should help clear up heater anodes. viewtopic.php?f=11&t=3660&hilit=heater
Never seen them on raw water cooled engines however if you have closed cooling, there will be one in the heat exchanger.
There may be exceptions which Viper will hopefully clear up.
Has thanked: 469 times
Been thanked: 1765 times
Postby Viper » October 27th, 2023, 7:09 am
Ya typically only fresh water cooled engines (coolant) will have anodes in the exchangers. Some oil coolers though in both raw water and fresh water cooled applications will have anodes too. Crusader's "U" cooler is a perfect example of that.
Mikwallace
Postby Mikwallace » October 30th, 2023, 11:21 pm
I looked over both engines and the hot water heater today and neither have an anode. Strange that the generator and engines have the same type cooling system yet the genny has an anode but neither engine does? I have another question about the master shower sump, but I’ll put that in a plumbing thread.
Thanks for all the info!
1959 Larson 16’
1979 Caravelle 18’
:captain2:
:usa:
sbb2112
Vessel Info: 1982 Carver Monterey 2687
260 Mercruiser / Mercruiser Alpha sterndrive
1992 Carver 350 ACMY
454 Crusaders with V-drives
Has thanked: 2 times
Been thanked: 8 times
Postby sbb2112 » March 5th, 2024, 6:32 pm
I replaced our water heater and found that there was no anode in it as received. It is a Kuuma. I had to order one. it was only about $20. cheap insurance.
