396 Motor Yacht
- KyleR
- Vessel Info: MV Verity
2002 Carver 396
- Has thanked: 153 times
- Been thanked: 137 times
Re: 396 Motor Yacht
2002 Carver 396
- Keysguy
- Vessel Info: 396 Carver
- Has thanked: 8 times
Re: 396 Motor Yacht
- Keysguy
Re: 396 Motor Yacht
- KyleR
2002 Carver 396
Re: 396 Motor Yacht
2002 Carver 396
- 650Guy
- Captain
- Been thanked: 40 times
Re: 396 Motor Yacht
- Aft Shower. Check for soft wood at the bottom under the glass door. I believe I did a string on my repair. I'll shoot it over if I can find it.
Here is a chart I made for mine, seems to work pretty good. My speeds are a shed lower than book speeds but otherwise it works well. Let me know if you want the excel spreadsheet I used to make this and you can adjust it as you feel the need. Not sure I can share that kind of stuff via this forum.
[image][/image]
- Keysguy
Re: 396 Motor Yacht
Thank you very much! Lots of good information. I'll let the surveyor know to look at that area. the 8th is the day. BTW I grew up in Vermilion and graduated from HS there. For 4 years 1986-1990 worked for South Point Marine Towing out of Huron. Fall of 1990 I moved to Key West and I've been in the Lower Keys ever since.
- KyleR
2002 Carver 396
Re: 396 Motor Yacht
2002 Carver 396
- Keysguy
Re: 396 Motor Yacht
- KyleR
2002 Carver 396
Re: 396 Motor Yacht
I know that some of the issues others have posted on here have helped me "catch" several conditions on my boat that were a problem waiting to happen.
Good luck in your search!!
2002 Carver 396
