Howdy from Kemah, Texas
wsp2
Vessel Info: 1995 Carver 440
Has thanked: 10 times
Postby wsp2 » April 17th, 2024, 2:47 pm
We purchased a 1995 Carver 440 about a month ago and are getting it ready for the Great Loop. So much to do and learn I'm feeling a bit overwhelmed! I'm fairly handy but haven't done much with boats yet. Several issues were found during the survey but the boat is in good shape considering it's a 1995. Looking forward to being here and will try to avoid asking really dumb questions.
Bill P
1995 Carver 440
"Tempest"
Kemah, Texas, USA
Been thanked: 490 times
Re: Howdy from Kemah, Texas
Postby waybomb » April 17th, 2024, 3:26 pm
Welcome aboard!
Cooler
Home port: Menominee, MI
Has thanked: 68 times
Been thanked: 413 times
Postby Cooler » April 17th, 2024, 4:15 pm
Welcome aboard! No such thing as a dumb question when it comes to boats. Boat stuff is way more complicated then non-boat stuff. Great production year, by the way. Ask away!!!!! 8-) er
Cooler By The Lake
Been thanked: 470 times
Postby RGrew176 » April 18th, 2024, 1:02 am
Welcome Aboard. My Grandfather told once that the only DUMB question is the one you don't ask. There are many members here with knowledge to share. Good luck with your Carver and good luck when you do the loop. Hope you have many fine adventures aboard your Carver.
Postby g36 » April 18th, 2024, 9:40 am
Welcome, I have aspirations to do the loop one day too. If you decide to chronicle your loop adventure make sure you keep us updated . This is a great forum.
ColRon
“Escape Plan”
Has thanked: 77 times
Been thanked: 157 times
Postby ColRon » April 18th, 2024, 11:49 am
Welcome Aboard
Ron
“Escape Plan”
Murray, KY
:usa:
Cooler
Postby Cooler » April 19th, 2024, 11:20 am
Carver's 1995 production year featured a lot of coremat construction. The hull below the waterline +6" is solid fiberglass. Above that, up to the rub rail, is coremat. Instead of balsa core, coremat is more of a plastic panel that can not absorb water. Keeps the hull stronger over the long run. Not 100% sure your 440 was built that way, but highly likely. If your surveyor mentioned anything about moisture content being very low along the hull, that would tell you it is coremat. 8-) er
Cooler By The Lake
Postby Viper » April 20th, 2024, 9:24 pm
Welcome aboard. We're a good group here and always willing to help so feel free to reach out.
pepmyster
8.1 Volvo Penta
Fresh water boating
Has thanked: 492 times
Been thanked: 210 times
Postby pepmyster » April 22nd, 2024, 5:55 am
Welcome!!!!!!!!!!!!!!!!!
wsp2
Postby wsp2 » April 22nd, 2024, 4:54 pm
Cooler wrote:Source of the post Carver's 1995 production year featured a lot of coremat construction. The hull below the waterline +6" is solid fiberglass. Above that, up to the rub rail, is coremat. Instead of balsa core, coremat is more of a plastic panel that can not absorb water. Keeps the hull stronger over the long run. Not 100% sure your 440 was built that way, but highly likely. If your surveyor mentioned anything about moisture content being very low along the hull, that would tell you it is coremat. 8-) er
Thanks. Moisture readings were good except in one place - the rear port panel near the window. Looks like the window seals are leaking and getting behind the wall. It's one of the things we're investigating. There were also a number of blisters below the water line which will need to be dealt with.
Bill P
1995 Carver 440
"Tempest"
Kemah, Texas, USA
