Gen Runs but Not creating power
Re: Gen Runs but Not creating power
Postby Midnightsun » May 1st, 2024, 5:40 am
JimN wrote:Source of the post I haven't worked on or with Onan generators, but the shop where I took a friends' Kohler from his '89 Santego 38 told me that the generator should never be started with loads, nor should the switch be thrown to Ship's Power immediately after startup.
YMMV.
Good to see that it's working.
Although this is viewed as good practice I have never done so on the Avanti or now on the Carver and never had an issue.
I have a whole house unit at home. The 200A transfer panel switches over immediately after a power failure is sensed, it then fires up the generator which furnishes the entire house while under load. Guess what I am saying is all automatic home generators are started under load all the time.
KyleR
Vessel Info: MV Verity
2002 Carver 396
Twin Cummins 6BTA 370HP
Has thanked: 153 times
Been thanked: 138 times
Postby KyleR » May 1st, 2024, 8:56 am
It's definitely not ideal to start it loaded, but I'd be more concerned about all the electronics and motors that are seeing low voltage (i.e. drawing large current) as the generator comes up to speed. Also there is probably a lingering (although relatively short) period when the generator is trying to stabilize itself so all your loads are seeing fluctuating voltages and currents. Same applies when shutting it down however the gradual voltage drop/higher current typically lasts longer as the generator winds down.
Again, probably minimal impact on the generator, not so great for the loads.
As for emergency generators, all the ones I've ever looked into actually start and come up to speed first, then the automatic transfer switch gets flipped. Just my 2 cents. :-D
MV Verity
2002 Carver 396
Alanna Mo Cree
Twin 8.1Gi Volvo Penta FWC
Has thanked: 46 times
Been thanked: 70 times
Postby Alanna Mo Cree » May 3rd, 2024, 6:22 pm
This discussion is precisely why I preferred my manual transfer switch on my last boat (not a Carver). I've already forgotten about the auto transfer switch on the Carver once and had a rough start of the generator under load. It was a reminder of why I use checklists.
My old checklist was easier IMHO:
Startup
    Cabin Door CLOSE
    Generator Master Switch START
    — WAIT FOR GENERATOR START —
    Generator Exhaust CHECK
    AC Transfer Switch GENERATOR
    Shorepower Pedestal OFF
    Shorepower Cord STOW
Shutdown
    Shorepower Cord CONNECT
    Shorepower Pedestal ON
    AC Transfer Switch SHORE
    — WAIT FOR GENERATOR COOL —
    Generator Master Switch STOP
    Bilge Blowers OFF
    Cabin Door AS REQ.
With the auto transfer switch there is a lot more to it:
Startup
    Cabin Door CLOSE
    A/C Unit FWD S/R OFF
    A/C Unit Salon OFF
    A/C System Water Pump OFF
    Shorepower #2 OFF
    Shorepower #1 OFF
    Shorepower #1 ON
    Shorepower #1 Volts NOMINAL
    Shorepower #2 ON
    Shorepower #2 Volts NOMINAL
    A/C System Water Pump ON
    A/C Unit Salon ON
    — WAIT FOR A/C UNIT START —
    A/C Unit FWD S/R ON
    Shorepower Cords STOW
Shutdown
    A/C Unit Salon OFF
    Shorepower #2 OFF
    Shorepower #1 OFF
    Shorepower Cords CONNECT
    Bilge Blowers OFF
    Shorepower #1 ON
    Shorepower #2 ON
    A/C Unit Salon ON
    A/C Unit FWD S/R ON
    Cabin Door AS REQ.
Maybe the manual shut down of the A/C system is overkill, but instead of having a momentary blink of power switching from ship to shore or vice versa I know there is going to be a few minutes without AC for the A/C. I also try to avoid having both systems come up at the same time because those compressor starts are brutal on the amp draw.
Charlie & Jennifer
2003 Carver 360 Sport Sedan
Twin Volvo 8.1Gi
Photo Album
650Guy
370 Cummins
Been thanked: 40 times
Postby 650Guy » May 8th, 2024, 7:32 am
what a great discussion! Generators are awsome and awful all at the same time! having one is just an amazing addition and proper use is key! when they have troubles... they are awful cause nobody wants to work on them (at least around me!)
650Guy
370 Cummins
Postby 650Guy » May 8th, 2024, 7:38 am
Alanna Mo Cree wrote:Source of the post This discussion is precisely why I preferred my manual transfer switch on my last boat (not a Carver). I've already forgotten about the auto transfer switch on the Carver once and had a rough start of the generator under load. It was a reminder of why I use checklists.
Startup
    Cabin Door CLOSE
Shutdown
    Bilge Blowers OFF
    Cabin Door AS REQ.
Startup
    Cabin Door CLOSE
    A/C Unit Salon OFF
    Shorepower #2 OFF
    Shorepower #1 OFF
    Shorepower #1 ON
    Shorepower #2 ON
    A/C Unit Salon ON
    A/C Unit FWD S/R ON
Shutdown
    A/C Unit Salon OFF
    Shorepower #2 OFF
    Shorepower #1 OFF
    Bilge Blowers OFF
    Shorepower #1 ON
    Shorepower #2 ON
    A/C Unit Salon ON
    A/C Unit FWD S/R ON
    Cabin Door AS REQ.
This is great!! in my line of work we live (and hopefully not DIE) by checklists! Im totally going to customize this for my boat and tape it to the inside panel for use!!! THANK YOU!
Return to “Electrical”
