Carver 396 Shifter/gear shift Question
paulr
Vessel Info: 396 CY Aft Cabin 2001 8.1 Crusaders
Has thanked: 54 times
Been thanked: 32 times
Postby paulr » April 28th, 2024, 11:53 am
Hello all,
I have a 2001 CY396 with stiff shifter/throttle controls. Are these supposed to be electrically assisted?
Re: Carver 396 Shifter/gear shift Question
Postby Viper » April 28th, 2024, 3:19 pm
Unless there was an upgrade done by a previous owner, I doubt it. Most likely a shift cable issue unless it's set up too tight at the remote or the remote itself is worn.
paulr
Postby paulr » April 29th, 2024, 6:17 pm
Thanks Viper
KyleR
Vessel Info: MV Verity
2002 Carver 396
Twin Cummins 6BTA 370HP
Has thanked: 153 times
Been thanked: 137 times
Postby KyleR » May 1st, 2024, 10:18 pm
Mine are not electrically assisted. Just cables directly from the helm to the engines/transmissions.
MV Verity
2002 Carver 396
paulr
Postby paulr » May 4th, 2024, 6:00 pm
Problem solved, the cables in the engine room just needed a little oil and to be worked back and forth.
KyleR
2002 Carver 396
Postby KyleR » May 4th, 2024, 6:49 pm
Thanks for the follow-up!!
MV Verity
2002 Carver 396
Postby Viper » May 6th, 2024, 9:46 pm
The oil may just buy you some time in my experience. If they've been stiff for a while, chances are that the inner lining is worn somewhere like a turn/bend. Oil will help the cable move easier through there but it doesn't cure the underlying cause. Once there's slop in there because of the wear, it'll wear faster. Oil can be a pain after a few years so we used to pump regular engine coolant through cables. Worked great but again it didn't cure the cause. Can't be bothered doing that anymore, I replace the cables once and they won't come back to haunt me a couple of years later. FWIW, the stock cables typically used in most builds aren't the best, and the routing is just as or more important than cable quality.
Users browsing this forum: No registered users and 58 guests
