Ac intake water valve location
- Buggin321
- Vessel Info: 1988 3227
- Has thanked: 1 time
1988 3227
- Been thanked: 654 times
Re: Ac intake water valve location
- Been thanked: 1111 times
- Has thanked: 602 times
- Been thanked: 1310 times
Buggin321 wrote:Source of the post Quick and easy question. Newbie here and looking to turn on ac system. Where is the intake water valve located thank you
1988 3227
Welcome to the forum, find your AC unit and follow the hose is the simple answer. On that particular boat there is a hidden access under the mid cabin bed mattress that many don't find, not sayin it is there just a little info.
Good luck with the new boat.
- Cooler
- Has thanked: 68 times
- Been thanked: 413 times
- buster53
- Has thanked: 10 times
- Been thanked: 285 times
g36 wrote:Source of the post I don't know your specific boat however I will suggest you pull up every floor access panel you can find and take a light and find all your seacocks and familiarize yourself with what is under each one. You should easily be able to locate this ac seacock there will be a pump withn close proximity to it. In case of an emergency you will also have the knowledge of your boat to possibly prevent a disaster.
Best advice and I will add, Carver gets real creative in hiding access panels. Look under berths as well. On my boat, I even have some panels hidden under carpeting. Previous boat, I had a panel inside a galley cabinet and a small one underneath the step going down to the galley. Find ALL your thru hulls, bilge pumps, sump pumps and identify any and all hoses, where they start from and where they end and their purpose. Knowing all this now will come in handy someday if and when the s..t hits the fan.
- boh50
