Genset running out of fuel
- MyPleasure
- Vessel Info: 1992 Carver 36 aft cabin with Volvo 740b engines. Westerbeke 5kw generator. Bought the boat in Portland Oregon in June, and a friend and I brought it up to Sidney, BC. Great trip!
- Has thanked: 2 times
- Been thanked: 23 times
Thanks for your help again!
1st Carver 1987 32 Aft Cabin
3rd Carver 1995 350 Voyager
- Been thanked: 490 times
Re: Genset running out of fuel
- Been thanked: 654 times
- buster53
- Has thanked: 10 times
- Been thanked: 285 times
Also, the pick up tubes for the genset are shorter than the main engine pickup, to keep you from running the tank empty just running the genset. I used to have a Carver 3807 that needed at least 1/3 tank in order to run the genset. Once the fuel got down to that level, it could no longer get fuel and shut down.
- MyPleasure
I’m just wondering if there’s a problem with the switch itself? Could it be gummed up with old fuel? I guess I’ll try removing the switch and see if it has any fuel buildup or something.
- Has thanked: 603 times
MyPleasure wrote:Source of the post I’m just wondering if there’s a problem with the switch itself? Could it be gummed up with old fuel?
That is certainly possible, take it apart and inspect the valves as a first check.
- MyPleasure
This is all theory, but I can’t think of any other reason that the generator is being starved of fuel. First thing I’ll try is tightening the packing nut, but I’m going to pick up a new valve (switch) in case.
Thank you guys for your help!
Do you pull from one tank or the other or are the lines teed into the engine feed lines somewhere ?
Air infiltration can be an issue , I have experienced that before especially when the generator feed line is not dedicated and it pulls fuel from the other unit attached depending on how the lines are run.
Yes, I agree a pic would be good, I like the 1/4 turn full flow ball type, not a fan of fuel valves with packing.
- MyPleasure
There are 3 fuel selector valves in the fuel system with one for each engine and its corresponding fuel tank, and then they are teed to a separate valve which supplies fuel to the generator. It looks like I can switch each engine to run off of either fuel tank.
I will take some pictures of the setup next time I’m at the boat.
