Genset running out of fuel
- Has thanked: 602 times
Re: Genset running out of fuel
If so shut off the fuel to engines valving ( isolate the mains ) while running the gen and see if the same thing occurs.
- MyPleasure
- Vessel Info: 1992 Carver 36 aft cabin with Volvo 740b engines. Westerbeke 5kw generator. Bought the boat in Portland Oregon in June, and a friend and I brought it up to Sidney, BC. Great trip!
- Has thanked: 2 times
- Been thanked: 23 times
I know that the generator fuel pump is working properly, it just seems to run out of fuel after 10-20 minutes. Like I said earlier, I’ll check the current valve to make sure that there is no leak, and if that doesn’t seem to be working properly, I’ll install a new switch.
1st Carver 1987 32 Aft Cabin
3rd Carver 1995 350 Voyager
Good idea checking for air infiltration. It is still good practice to have the gen on its own fuel supply lines from its own tank pickups though.....good luck hopefully it is something real simple.....
- MyPleasure
I never checked how the generator on our 4207 got its fuel, but I know that it did draw its fuel from the port tank. Being diesel, it was great to have the fuel transfer pump to help level the boat out after using the generator. But I never had much for solar power back then, so the generator was used a lot more.
I would like to hear from other owners of this model with gas engines to hear how their generator fuel lines are installed? I think this model is a 1992 3608, I believe that they were built from 1990 - 1995, then they extended the swim platform and called it a 405 - 406.
- ColRon
- Has thanked: 77 times
- Been thanked: 157 times
“Escape Plan”
Murray, KY
- KyleR
- Vessel Info: MV Verity
2002 Carver 396
- Has thanked: 153 times
- Been thanked: 138 times
I finally figured out that it was over heating. And while the impeller had been replaced and it was pumping water, it wasn’t pumping enough due to a blockage from bits of previous impellers.
Similar thing happened with ours - but it turned out that the intake strainer (the exterior one on the hull) had been painted over multiple times and was clogged. Luckily I figured it out and was able to thoroughly clean it out during a short-haulout to swap props. Ran perfectly after that.
Good luck and please keep us posted when you find your solution!
2002 Carver 396
- MyPleasure
It’s definitely a fuel problem, the fuel pump is dry after it stalls. It’s like there’s a fitting not tight, and the fuel pump looses its vacuum, and the fuel pump is not pulling fuel. I took the fuel system supplying the generator completely apart and found no fuel restrictions of any kind, and the tank selector valve is in perfect working order. I actually bought a new switch valve, and found that the ports were not properly aligned, which wouldn’t allow a full amount of fuel from the factory, unlike the original one,
I am wondering if the 1/4” selector valve currently installed for the generator is big enough, but it’s only a 3 cylinder Westerbeke, so it shouldn’t burn a lot of fuel anyway.
Anyway, another project for after the weekend.
- Been thanked: 654 times
