Twin pleasurecraft 302 water pump orientation
- hlfm
- Vessel Info: 1980 Santa Cruz ‘28
- Been thanked: 3 times
- hlfm
Re: Twin pleasurecraft 302 water pump orientation
- Been thanked: 1110 times
- Has thanked: 602 times
- Been thanked: 1309 times
- hlfm
km1125 wrote:Source of the post Should be easy to tell which is the inlet and which is the outlet on the pump, then looking at the pulley and determining which direction it turns should tell you how to orient the pump housing.
It SHOULD BE easy, but I am questioning my ability to determine. Especially since melting the impeller.
- hlfm
bud37 wrote:Source of the post Is the other pump in the pic the original from the side ?
Yes
- hlfm
bud37 wrote:Source of the post Is the other pump in the pic the original from the side ? Maybe this can help a bit...
So the intake and out are opposite,this is why fried it.
Anyway, once you get this sorted out, remember to assemble the new impeller with dish soap to lube it for start up then you can see the bubbles in the exhaust discharge as well.
Fyi , even a small split in the suction side hose under the clamp can short circuit a pump ( keep it from pumping) and if you keep trying the impeller will be ruined to the point of not pumping even if the pump is installed correctly.
Good practice may be to cut a small amount off the end of the hose to create a fresh joint if you have enough slack, inspect the hose there.
- KyleR
- Vessel Info: MV Verity
2002 Carver 396
- Has thanked: 153 times
- Been thanked: 137 times
2002 Carver 396
Is one engine a counter-rotator? If so, does that pump mount differently or set up differently for counter-rotation? If so, this matters and which port the intake hose goes to makes a difference.
Users browsing this forum: No registered users and 188 guests
