Norcold fridge short cycling
camsaure@aol.com
Has thanked: 25 times
Been thanked: 6 times
Postby camsaure@aol.com » July 2nd, 2024, 12:07 am
According to the paperwork with the Mariner boat it had a model DE828. But now I pulled the fridge and it appears to have been replaced.. The one I have issues with has only one compressor and has CFC free refridgerant 134 A. The label says Sawafuji Model SK-515M,50hz, Lot no 02-1-16. On a bar code label it says DE461 and OIN-0168. It short cycles on both12 volts and 110 volts. I tried disconnecting the cooling fans and nothing changed. I am not sure where the thermostat is located in order to try and hot wire it. Where do I go from here?
Rocketman
Vessel Info: 2009 44 Sojourn w/ Volvo Diesel D6-500 engines and IPS drive system.
Been thanked: 22 times
Re: Norcold fridge short cycling
Postby Rocketman » July 2nd, 2024, 7:37 am
Try disconnecting the power adapter module and wiring the 12v input direct to the output going to the compressor.
I have had problems in the past with the power adapter module relays and not allowing the unit to run.
Has thanked: 78 times
Been thanked: 1093 times
Postby km1125 » July 2nd, 2024, 9:17 am
Rocketman wrote:Source of the post Try disconnecting the power adapter module and wiring the 12v input direct to the output going to the compressor.
You CANNOT do that on these compressors. These are AC compressors. They have a big electromagent surrounding the piston and the AC on the electromagnet causes the piston to oscillate back and forth (and there's springs on each side of the compressor to help). When you are running on DC, the DC actually goes through and inverter to create an AC waveform to run the compressor. The AC voltage on the compressor is between 26 and 40 volts, depending on the model.
Postby km1125 » July 2nd, 2024, 9:21 am
camsaure@aol.com wrote:Source of the post .... I am not sure where the thermostat is located in order to try and hot wire it. Where do I go from here?
There is a thermostat sensor screwed into the bottom of the evaporator (freezer) on the bottom. If you slide out the drip tray you should be able to see it. It's a thermister. The power supply uses that, along with the variable resister in the "thermostat (the knob where the on/off switch is) to determine the actual temp and the desired temp to know if it needs to activate the compressor or not. You can't just "short it out" to turn it on.
camsaure@aol.com
Postby camsaure@aol.com » July 2nd, 2024, 11:09 am
Thankyou for that warning! Do you happen to know which part could be at fault? power supply, thermisistor, or temp control? Also where I could best possibly find replacements?
camsaure@aol.com
Postby camsaure@aol.com » July 2nd, 2024, 1:44 pm
I think I have low voltage coming out of the power supply to the compressor.
Postby km1125 » July 2nd, 2024, 4:26 pm
camsaure@aol.com wrote:Source of the post I think I have low voltage coming out of the power supply to the compressor.
What did you measure? When you measured, was it with the compressor disconnected or connected?
You should measure both ways... with a load (the compressor) connected and then disconnected. Also measure both ACV and DCV to see what you get (so that's a total of FOUR measurements). Was the compressor warm at all?
I'll look for the documents on that model and see what I have. Might have some of the parts for it too.
camsaure@aol.com
Postby camsaure@aol.com » July 2nd, 2024, 11:56 pm
I need to get a better voltmeter and check again. I unhooked one wire when I checked it. I guess I need to perform more tests as you suggested. Thanks again.
Postby km1125 » July 3rd, 2024, 5:19 pm
camsaure@aol.com wrote:Source of the post I need to get a better voltmeter and check again. I unhooked one wire when I checked it. I guess I need to perform more tests as you suggested. Thanks again.
I PM'd you a troubleshooting document for the DE461 models. Lots of good info in there. Let us know what you find.
(tried to post the doc here but it would only let me attach picture files).
camsaure@aol.com
Postby camsaure@aol.com » July 3rd, 2024, 10:55 pm
Sorry, I dont think the attachment went through, I cant find it.
