Battery Question
- cjblovinlife
- Vessel Info: 1996 Santego 380
- Has thanked: 27 times
- Been thanked: 8 times
Battery Question
I have two systems a house set up with two AGM‘s and a cranking set up with two lead acid batteries. Both systems have the 2nd battery wired in parallel but system 1 is isolated from system 2 on the + side unless of course someone puts the battery switch in the BOTH position. HOWEVER ALL the negatives/ engine grounds are tied together.
My question: If my house system call it #2 is low at 9V and #1 system is good at 12.7 . Without hooking up any charger they will EQUALIZE… How does that happen?? Is it through the negative side of the circuit somehow?
Thanks so much for your wisdom I’m still learning.. should I separate the negative/ grounds for each system?
Re: Battery Question
Normally the start banks are left separate to make sure you have enough juice to get the motors up and running. One common mistake that gets new boaters into trouble is combining start and house bank which can leave you stranded.
- Has thanked: 602 times
Charge all up then disconnect your charger leads completely and see what happens. Remember there are parasitic loads hard wired to different batteries, like bilge pumps, CO monitors, radio preset maintain etc.
- cjblovinlife
The panel shutting down due to low voltage is new, I don't think I've seen that one before but a previous owner may have installed a low voltage cutoff device, check behind the panel. When you say the panel shuts down, does the main breaker trip? Does the panel DC meter drop to zero? No DC loads work at all?
When you note battery voltages are you looking at ship's meters or a multimeter?
Do you have an inverter?
cjblovinlife wrote:Source of the post I’m baffled if I separate the negatives on each system I suspect they won’t equalize but I haven’t done that yet
The DC grounds are all connected together on a boat.......there has to be a completed circuit for there to be power usage. Perhaps do some extensive continuity testing to find where the connection is on the positive side.
Clearly there seems to be a connection or leakage/ bad motor/isolators/inverters etc as has been mentioned ( eg. bilge pumps ), even those one, two, all switches have been known to be faulty but lets face it something is pulling one bank down under 9 volts ......did you test the banks at the batteries themselves.
What is using all that power or do you just have a bad battery, have you tested all your battery cell levels and individual Hydrometer readings to check for bad cells. I would do that to see if you have a good baseline.
How old is the house bank? House banks tends to be neglected by drawing it down too far when away from shore power causing an early demise over time. Right now it is being severely hurt by sitting at 9v when one considers 11.5v is 100% dead. I suspect you have a bad cell or bad battery on the house side, maybe even a direct internal short.
If connected to shore power, can you bring the battery SOC up to full? If so, then how long does it take to diminish the voltage once the battery charger is disconnected? Do you even have a charger? You do mention you have a NOCO 10 x 4 but it is not connected?
- cjblovinlife
A few answers to questions posed.
No I do not have an isolator or ACR
All batteries test good under load, disconnected from the system using Schumacher tester.
I do have the noco charger but have chosen not to hook it back up yet. I charge the house batteries off line then put them back just trying to simplify and troubleshoot and didn’t want another variable.
The sync guauge is interesting I did not disconnect that ..
I don’t know how to truly test alternators or voltage regulators all I know is to test voltage at battery while it’s running hoping for 13-14v
On the DC panel I’ll look for added components the mains do not trip all panel lights go dim and lose power I guess I should put a meter on the mains when that happens and at the switch.. all lines have been traced there are no black boxes
- cjblovinlife
Viper wrote:Source of the post Do you have a dual battery isolator for 2 alternators and 2-3 banks utilizing diodes? A faulty diode can leak back and essentially connect two banks together. Also, if you have a engine sync gauge, disconnect it and the module if applicable.
I’m looking at the boats voltmeters and verifying with my multimeter.
I don’t have an inverter
The sync module is interesting I’ll check that. I was wondering if I should get an act or isolater but haven’t yet , actually I was trying to figure out if the Noco genius essentially has an act built in .. I would think it must but they don’t use that terminology
After you have charged the batteries and put them back, how long before it drops to unacceptable levels?
Is the fridge shut off? Could be the AC side is not functioning and it operates from DC only.
