Wall vinyl separating at door edge - FIXED!
KyleR
Vessel Info: MV Verity
2002 Carver 396
Twin Cummins 6BTA 370HP
Has thanked: 153 times
Been thanked: 137 times
Postby KyleR » July 9th, 2024, 4:45 pm
Since buying our boat we have had an ongoing issue with the vinyl wallcovering in the master stateroom separating where it meets the door frame. See pics.
MV Verity
2002 Carver 396
KyleR
2002 Carver 396
Re: Wall vinyl separating at door edge - FIXED!
Postby KyleR » July 9th, 2024, 4:50 pm
Then I had an idea about using vinyl "piping" to trim out the door frame which would hide the separation and maybe even prevent it from getting worse. I looked around and found the following on Amazon. You can order samples for $2 each to get an idea for color matching. We ordered Bone, Off-white and light tan....and ended up going with the off-white. Then we ordered 10yds to do the areas we were having issues with.
MV Verity
2002 Carver 396
KyleR
2002 Carver 396
Postby KyleR » July 9th, 2024, 4:52 pm
There is a little void behind the door trim that allows the piping to slide in and it stays in place by just a friction-fit, so there is no gluing/fasteners to have to deal with.
MV Verity
2002 Carver 396
KyleR
2002 Carver 396
Postby KyleR » July 9th, 2024, 4:55 pm
And here is the final installation. When I upload a vertical pic of the whole door, the site rotates it, so here is a section that keeps the perspective normal. :-D
MV Verity
2002 Carver 396
Been thanked: 1112 times
Postby km1125 » July 9th, 2024, 8:19 pm
Looks good!
Postby g36 » July 9th, 2024, 8:55 pm
Looks good. No one would ever know.
