Closed cooling overheating - solved
- Youghster
- Vessel Info: 1995
Santego 310
Small Lake Use - Location: SW PA
- Has thanked: 5 times
- Been thanked: 7 times
Re: Closed cooling overheating - solved
- pepmyster
8.1 Volvo Penta
- Has thanked: 492 times
- Been thanked: 210 times
- Jay Fusaro
- Vessel Info: 1998 445 Aft Cabin
- Has thanked: 75 times
- Been thanked: 3 times
- Youghster
- Vessel Info: 1995
Santego 310
- Raven
I am having the exact symptoms at idle( heat guage creeps up) but at higher rpm it cools down to normal
Raven wrote:Source of the post is the impeller in the water pump replaceable? or do you have to replace the whole assembly?
You might want to start a new thread for your issue, or you'll get confusing responses mixing up your issue with the OPs.
But -to answer your question- no circulating pump I've seen has a field-replaceable impeller. They are usually pressed on the shaft with a hydraulic press. But if you were referring to the raw water pump, then yes, those always have replaceable impellers.
