Lifepo4 Batteries
Re: Lifepo4 Batteries
Postby Midnightsun » March 9th, 2024, 12:06 pm
KyleR wrote:Source of the post So your alternators go to your isolators, which feed your house batteries, which then feed your lithium bank via the DC-DC chargers? Is that right?
Correct.
KyleR
Vessel Info: MV Verity
2002 Carver 396
Twin Cummins 6BTA 370HP
Has thanked: 153 times
Been thanked: 139 times
Postby KyleR » March 9th, 2024, 1:02 pm
Thanks! Couple more questions if you don't mind: :-D
The way my system seems to have been designed from the factory is that there is also a feed from the port isolator that goes to the house battery to keep it charged from the alternators while underway. It seems to me this wire has to come off otherwise the alternators still have a direct charge path to the lithium bank. Did you run across this same setup?
Also, since my alternator sensing leads currently run to the house bank (currently flooded lead acid), it seems I should remove it from the house bank and instead run it to the applicable starter battery. Does that sound correct?
Sorry for all the questions but I want to make sure I get this right from the start and don't damage anything or have to do rework! :banghead:
MV Verity
2002 Carver 396
Postby Midnightsun » March 9th, 2024, 1:35 pm
Yes on both accounts. No communication between LifePo4 bank and Lead Acid bank. My isolators were set up the charge between 3 banks (start, start, house) , I simply disconnected the lead going to the house bank. This way I had a fall back plan if I overlooked something and needed to go back to lead acid house bank. Nothing to report that would have me do so.
KyleR
2002 Carver 396
Postby KyleR » March 9th, 2024, 1:59 pm
My thoughts exactly. And I'm glad to hear there were no unforseen consequences. Thanks again!!
MV Verity
2002 Carver 396
KyleR
2002 Carver 396
Postby KyleR » July 15th, 2024, 1:06 pm
To close out my part of this thread, I ended up going with the Victron Orion XS 50amp DC-DC Charger. I came off my STBD starting battery through a 60a breaker, to the Orion XS, through another 60a breaker and then to the house lithium bank. Works perfectly and keeps the house bank charged while underway. Thanks to all who chimed in with their experiences and wisdom! Kyle
MV Verity
2002 Carver 396
mikesparker
Vessel Info: 1985 3227 w/Crusader 220s
Has thanked: 28 times
Been thanked: 3 times
Postby mikesparker » July 22nd, 2024, 8:32 pm
Kyle, I know the Orion XS is a great DC/DC...I'm curious about why you went with 60amp breakers if it's only a 50amp charger? Also, why only 1 charger instead of the 2 as per midnightsun? I'm installing a LifePO4 setup next month and have some decisions to make!
KyleR
2002 Carver 396
Postby KyleR » July 22nd, 2024, 9:09 pm
Since it is designed to pass 50amps, I wouldn't want to use anything less than or equal to 50 amp, thus I went with a 60amp breaker. Plus, it is what is recommended by Victron in the product documentation. ;-)
Each of my alternators feeds it's own isolator, and both of my isolators are cross connected. With this setup, if one alternator goes out, the other alternator will pick up the load. So, no real reason to have two DC-DC chargers. I have confirmed proper operation by running only the port engine and got proper charging, then I ran only the starboard engine and got proper charging.
Hope that helps!
Kyle
MV Verity
2002 Carver 396
mikesparker
Postby mikesparker » July 22nd, 2024, 11:13 pm
Ok that makes sense. So forgive the ignorance here, but would two 30amp chargers putting out a combined 60amps be advantageous? Or does the efficiency of the XS make up for the 10 amp "deficiency"?
mikesparker
Postby mikesparker » July 22nd, 2024, 11:34 pm
KyleR wrote:Source of the post To close out my part of this thread, I ended up going with the Victron Orion XS 50amp DC-DC Charger. I came off my STBD house battery through a 60a breaker, to the Orion XS, through another 60a breaker and then to the house lithium bank. Works perfectly and keeps the house bank charged while underway. Thanks to all who chimed in with their experiences and wisdom! Kyle
Can you confirm that you came off your STBD HOUSE battery and not the starting battery? I'm confused...lol
KyleR
2002 Carver 396
Postby KyleR » July 22nd, 2024, 11:57 pm
Excellent catch!! Yes, I came off the STBD STARTING battery (not house). I just corrected the original post. Thanks for pointing that out - that definitely would create confusion! :confused:
MV Verity
2002 Carver 396
Return to “Electrical”
