Can't find neutral
tonym
Topic author - Scurvy Dog
- Vessel Info: 1980 Santa Cruz 2866
T302 pleasure crafts
B/W velvets - Location: Sandusky ohio
- Has thanked: 4 times
Can't find neutral
Any suggestions as to why I can't find neural on a B/W Velvet drive ?
thanks,
tony
tightfit
- Been thanked: 3 times
Re: Can't find neutral
LOL
- mjk1040
- Been thanked: 246 times
Mike
- Has thanked: 469 times
- Been thanked: 1765 times
tonym wrote:Source of the post Greetings All,
thanks,
tony
It won't come out of gear or nothing happens when you try to start the engine?
tonym
tonym
If you manually move the lever into the neutral detent and the shaft continues to spin, you likely have stuck clutch plates. Check the oil to ensure it's clean and at the right level. Short of that, it's likely a teardown to fix the problem. Could be warped plates, or a control valve problem.
tonym
will start with the easy one the control valve maybe its gunked up, fluid seems to be clear.
do you know what kind of life i should expect from the ford 302's ?
tonym wrote:Source of the post ....do you know what kind of life i should expect from the ford 302's ?
Really depends on maintenance history, how the boat was used over the years, etc. more than anything. If they were always well maintained, they should last a long time, poorly maintained; not so much. While I don't stress too much about the number of hours on an engine, it's a good gauge on whether that time is soon approaching.
Why are you asking? Do you have a runability issue? How many hours on her? If you're wondering about her condition, a compression test, vacuum test, etc. will tell you a lot.
