port engine not starting
- Rayjs148
- Has thanked: 18 times
Observations: noticed when first turning ignition key the tachometer jumps up an down and the Engine Sync gauge will jump over to port side. Spark seen from ignition coil to dist cap, not always seeing a spark from dist cap to plugs.
replaced start relay, ignition coil ,dist cap, rotor and get the same results.any thoughts, thanks
- Been thanked: 490 times
Re: port engine not starting
- Rayjs148
- Has thanked: 602 times
Rayjs148 wrote:Source of the post Thanks for the reply, my observations suggest problem is ignition related as we do not see a spark from Dist cap to plugs but do see a spark form ignition coil to dist cap, just not sure where to go from there.
What year is your boat ? Is it points or does it have a module in the distributor ??
- Rayjs148
