New A/C verses older ones.
VicB
Vessel Info: 1988 Carver 3807
Has thanked: 41 times
Been thanked: 11 times
Postby VicB » August 18th, 2024, 2:00 pm
88’ Carver 3807. Have 3 A/C units on my boat. 16, 9 and I think 6k btu. I believe they are original. They are freon R-22 units. They do reasonable, but at the peak of summer they struggle. Understandble with condenser water coming from the lake that’s in the 90s. We went to Kentucky to look at a newer carver yesterday. Water may have been a bit cooler, but it was comparable. The two units on that boat were less that a year old. Blowing absolute snowballs. Are the newer units that much better? I thought ours were fine until we experienced those.
Re: New A/C verses older ones.
Postby Midnightsun » August 18th, 2024, 2:26 pm
The newer units perform better, are much quieter, and draw less power. That being said, here is what I have been replacing mine with on the last 3 boats. Totally satisfied. https://www.marinaire.com/Products-s/12.htm
Postby km1125 » August 18th, 2024, 2:59 pm
If you haven't already, you also might want to do some flushing on your units to make sure there's no growth inside the water passages. That insulates and also slightly slows the flow of water. Saltwater guys have to do it sometimes multiple times a summer but in the freshwater side it's almost forgotten about. Still can be an issue with ~36 years of flow going through them.
Merkinbrumsky
Vessel Info: 1985 Carver Voyager
Has thanked: 53 times
Been thanked: 38 times
Postby Merkinbrumsky » August 18th, 2024, 4:55 pm
Midnightsun wrote:Source of the post The newer units perform better, are much quieter, and draw less power. That being said, here is what I have been replacing mine with on the last 3 boats. Totally satisfied. https://www.marinaire.com/Products-s/12.htm
Are these available for purchase in Canada? The marinaire site does not have Canada as a selectable choice for shipping. My older 10,000 btu dometic unit is on the way out and needs replacing. Defender Canada site has the dometic for about $3250 can + hst. The marinaire unit is a little easier on the wallet.
Postby Midnightsun » August 18th, 2024, 8:32 pm
Not sure, I would give them a call to see the possibilities. I had mine sent to to my brothers house in NH. He comes up and I go down so it's not and issue transporting it up.
Postby tomschauer » August 18th, 2024, 10:49 pm
If you have a 12k btu unit, if it is working properly, it will provide 12,000 BTUs/hr of cooling. This is true for a brand-new unit or a 30-year-old unit. The only difference from old to new is the efficiency, or the watts per btu to provide the cooling. Newer units may also run quieter, but as far as capacity a BTU is a BTU.
Postby Viper » August 19th, 2024, 6:38 am
Try flushing the system first and make sure the filters if applicable and evaporators are clean
Postby g36 » August 19th, 2024, 10:22 am
Also if the air coming out is around 15-18 degrees cooler than ambient temp it's pretty much doing what it should.
VicB
Postby VicB » August 19th, 2024, 11:09 am
The heat load in my boat is pretty high. The stern gets the afternoon sun and it will blast you like an oven if you open a cabinet when the sun has been shining on the gel coat behind that cabinet for a few hours.
Postby bud37 » August 19th, 2024, 12:14 pm
This is one of those discussions that brings up the advantages of white or very light colored front salon window covering/bra. You can reduce the immediate interior temp that way from radiant heat considerably. That will lessen the load on the AC.
I know the black is nice looking and is useful in the shoulder seasons when heat is good but in the heat of summer , not so much perty.
