Genset running out of fuel
- MyPleasure
- Vessel Info: 1992 Carver 36 aft cabin with Volvo 740b engines. Westerbeke 5kw generator. Bought the boat in Portland Oregon in June, and a friend and I brought it up to Sidney, BC. Great trip!
- Has thanked: 2 times
- Been thanked: 21 times
Re: Genset running out of fuel
What I’ve found is, when the generator has been running for anywhere from 10-30 minutes, it runs out of fuel. If I start the main engines and run them for maybe 2 minutes, the generator has fuel again and runs fine. So the problem must be with the way that the installers tapped into the main engine fuel lines. I don’t know if the generator was a factory installation or not, so I don’t know who to blame for this one. Luckily, there seems to be plenty of fuel in the lines to start the main engines after the generator stalls.
Sometimes the generator will run for several runs before running out of fuel. I haven’t heard from anyone with a similar installation, so maybe ours is a one off, not sure. This winter I’ll do more investigation into the fuel lines, but for now, we can make it work for the rest of the summer.
1st Carver 1987 32 Aft Cabin
3rd Carver 1995 350 Voyager
- Has thanked: 78 times
- Been thanked: 1093 times
Did you already check, replace or otherwise rule that out as Waybomb suggested in post #2?
- MyPleasure
You can remove them and clean then, or just replace them. They are not very expensive (~20/ea?) They are often a source of trouble on older boats when fuel delivery is diagnosed as the issue.
- Has thanked: 598 times
- Been thanked: 1281 times
- MyPleasure
- MyPleasure
We’ll head out on the boat next week and see how the genset runs.
Thanks again for all the advice fellas!
- MyPleasure
- MyPleasure
A question , do you have an inline fuel filter like a Racor in your gen fuel line and have you eliminated the gen fuel pump as an issue ?
Also cutting into a line sometimes works better from a flow perspective if the split is a "y" used instead of a "t". I still say It is far better for each end use to have it's own dedicated fuel line, no in fighting....kinda like the kids...
Users browsing this forum: Jskhome62 and 11 guests
