Genset running out of fuel
- MyPleasure
- Vessel Info: 1992 Carver 36 aft cabin with Volvo 740b engines. Westerbeke 5kw generator. Bought the boat in Portland Oregon in June, and a friend and I brought it up to Sidney, BC. Great trip!
- Has thanked: 2 times
- Been thanked: 23 times
Re: Genset running out of fuel
Yes there is a Fuel/water separator in the generator fuel line which I replace at least once a year, and I put a new fuel pump on earlier this year. The new pump sounds just like the old fuel pump, so I’ll keep the old pump for a spare.
It’s funny that the generator will sometimes shut down from lack of fuel, then other days in will run and not ship up down at all?
After I cleaned the anti siphon valves, I blew them out with an air compressor. They made a fluttering sound when I did this, but I don’t know if that’s normal or not?
1st Carver 1987 32 Aft Cabin
3rd Carver 1995 350 Voyager
- MyPleasure
- MyPleasure
- MyPleasure
- MyPleasure
That might have been our last trip for this year, so I’ll try running the generator for 30 minutes or so this weekend when I go to the boat.
- Kruggy88
- Vessel Info: 1991 carver 638 santego
I took out the filter and made sure it was clear, I disconnected the fuel line into the carb and cranked to see if pump was working and it pumped fuel but wouldn’t start. I tried removing the line and cranking again but let it crank longer and it pumped fuel or a second or two than stopped. At this point I was stumped but than remembered switching the valve. So I turn it back to the port tank and it ran just fine.
Another annoying thing is non of my fuel selector valves have detents so if you are slightly off, you will be limiting fuel flow. I figured the selector valve was just off but haven’t had time to play around with it.
- MyPleasure
I never did figure out what the original problem was, but I now draw fuel for the geneator strickly from the starboard tank. The generator hasn’t run out of fuel while running off the starboard tank, but now after 3-4 days at anchor, the main engines crank forever before starting. Sometimes I even have to prime the engines before they will start. I would have thought that the anti siphon valves would stop the fuel from going back towards the tanks.
It might be that I have the valve selector switch for the generator fuel supply in the wrong position and it’s letting the fuel draw back from the engines, but I’ll keep trying different settings on tye fuel supply valve and see if I can fix this new problem.
- Has thanked: 602 times
Once the engines are running do they run fine ?
- MyPleasure
Luckily there’s a fellow in town that has been rebuilding distributors and carbs for the hot rod community for the past 65 years. He’s rebuilding and mapping my distributors now. The distributors are Pertronix that someone replaced years ago, and I’ve never checked them since I’ve owned the boat. Now I find out that both engines have been running with no mechanical advance this whole time!
It will be interesting to see if the engines run better, and hopefully get better fuel consumption with the rebuilt distributors.
- Been thanked: 490 times
