2000 Carver 356 breaker for battery charger.
- cpoint
- Has thanked: 208 times
- Been thanked: 32 times
This post is a follow-up to my previous one, but since that got a bit long with multiple topics, I’m starting fresh here.
Due to limited time on the boat over the past two years, I haven’t had a chance to work on some mechanical issues. My latest challenge is related to replacing the battery charger. The original one died, so I purchased a compatible replacement and installed it without any issues. However, I’ve noticed a problem: the house battery only charges when I have the selector set to BOTH (1+2).
I know from our previous discussion that the selector switch shouldn’t affect charging. But since I don’t have much time to troubleshoot, I’ve decided to replace the breaker under the stairs that controls charging for batteries 1, 2, and 3. All three breakers are currently in the ON position, yet the house battery (2) doesn't charge when I select 2 or OFF.
When I switch to BOTH (1+2), everything works fine and the house battery charges. If I leave it on 2 and turn on all powered systems, everything shuts off after a couple of hours. Switching back to BOTH restores power, and after a while, the house battery charges fully. From what we've previously discussed, I’m pretty sure the breaker for battery 2 is cracked or has gone bad.
Next time I’m at the boat, I plan to replace the breaker. Since I won’t be able to return for a week or two, I’d like to have the replacement ready beforehand. My question is: does anyone know which breaker switch would be a suitable replacement for the original one in a 2000 Carver 356? I’m assuming the original breaker is no longer available, but I’ll attach a photo of what I currently have. I’ve searched online but haven’t found a match, and I’m not sure what amps or specs I need to look for.
If anyone has replaced theirs or has information on where I can find a compatible breaker, I’d appreciate the help!
Thanks!
Re: 2000 Carver 356 breaker for battery charger.
Also, another option for you on the breakers in your pic is to figure out what size the battery breakers are and find another -less important- breaker in your panel with the same rating and swap the two. It's a little effort, but then you'll know if it's really a bad breaker rather than just replacing it and hoping.
- Been thanked: 654 times
- Has thanked: 603 times
I mentioned this before as a few of us had the same issue and it was broken connections etc in those panels.
- cpoint
- cpoint
- cpoint
If you can get it open even a bit, maybe a bright flashlight and mirror could help to inspect the goings on back there, and see if there is something keeping it from coming out further....past that I can't think of anything further, again I do sympathize as I have been thru similar.
Don't damage anything.
Just to add, not saying this is the problem, but needs to be crossed off the list of possibles in my opinion.
cpoint wrote:Source of the post KM, "Those breakers are near the "battery" end of the circuit. There should also be a breaker or fuse on the charger end of each battery circuit. Have you checked for that and made sure those were all, OK?" Where would this be? on the battery, close to battery? I have not seen anything where easily seen. Unless under the stair, where it is hard to open. I think the lines are too short maybe. I removed the screws where selector/switches are. Tried lifting and it was not coming up, so I did not want to force and have something pop out under. Is there some trick to lifting that panel without damaging anything? I tried to look under from engine room, but really not much space there and hard to see.
No, the ones in the panel with the pic are the ones "nearest the battery". Unless the charger is mounted very close to that, there should be another set of fuses and breakers near the charger. This is not always the case though, as older implementations didn't have that requirement. If you changed out the charger and didn't see breakers or fuses where the output wires went, then there probably aren't any there.
Anything in that panel under the step is a pain to get to. I've gotten to it a number of ways including pulling back the carpet on the step enough to remove the front step section off the hinge. It gives you a bit more accessibility but still not ideal because the wiring is so short. You should also check the forward cabinet in the aft cabin (TV), there is usually a panel that can be removed for access to the compartment under that step. It's still a fight reaching in there but every bit of access helps. I'm wondering though why the outputs from the charger went to the batteries and not the selector switch which is what I'm used to seeing.
Are you sure all three charger banks are actually working and that you haven't blown an internal fuse? Each output has one. It's either that, a bad breaker, it's hooked up wrong, wire is off, failed output on one of the charger banks, etc. A multi meter would go a long way here. At the very least, you'd be able to tell right at the charger if all three outputs are working.
You probably posted it already but was it a Pronautic P that you installed? If not, what?
