Replacing an AC Unit
Topic author
mrsparkj
Vessel Info: 1987 Carver Aft Cabin
Has thanked: 3 times
Postby mrsparkj » April 23rd, 2016, 9:52 am
My original AC unit, 1987 Carver Aft Cabin, has finally called it quits. Time to replace. Before dropping the $1500 for a new 16,000 BTU unit, I was going to ask experts out there is it really necessary to run AC all summer to help with the fiberglass hull of a boat? Heard opinions both ways. The reason I am asking was I was looking at getting a $400 portable unit that vents out the sliding window to use when I stay aboard and only run the unit when I am there vice all the time. I live in DC, gets humid in July/Aug but figured I could run fans when I am not there and I have window shades to help keep inside cool. Any thoughts?? Thanks in advance!!
Has thanked: 64 times
Been thanked: 481 times
Re: Replacing an AC Unit
Postby waybomb » April 23rd, 2016, 3:28 pm
I only run the ac when it's hot and we are on the boat.
Never heard of having to run the ac all the time
Lyndon670
Vessel Info: 2000 Carver 506
Volvo TAMD74EDC
Has thanked: 124 times
Been thanked: 140 times
Postby Lyndon670 » April 23rd, 2016, 6:24 pm
I have no idea what this means.... :confused: :confused:
I run the AC from the minute I get on the boat to the minute I go home. And when I am leaving, I place the 2 salon units, the front guest stateroom unit and the master stateroom unit into "humidity" mode until I return the following weekend.
Takes the dampness out of the boat.
Lyndon,
2000 Carver 506
FOXY JOE
Volvo 7.4TAMD
Queens Cove Marina
Georgian Bay, Ontario
Topic author
mrsparkj
Postby mrsparkj » April 23rd, 2016, 9:59 pm
Thanks for the responses. Fred, agree with your thoughts.....no need to run the AC when your aren't there......no one to keep cool!
Has thanked: 468 times
Been thanked: 1765 times
Postby Viper » April 23rd, 2016, 10:24 pm
That's a new one to me. The only reason I can think of for running them all the time would be to keep the humidity to a minimum. That would help minimize mould, musty odours, etc. but if you keep windows open a bit, a little breeze is all it takes to replace stale air, a fan helps too. Personally I don't like leaving my units on while I'm not there. Remember that they pump raw water, should the system spring a leak, a warm and humid cabin would be the least of your problems.
Lyndon670
Volvo TAMD74EDC
Postby Lyndon670 » April 23rd, 2016, 11:45 pm
With the humidity mode on, the pump isn't energized. The ECU monitors the humidity in the air and turns on the fan at intervals/speeds. Works great.
Lyndon,
2000 Carver 506
FOXY JOE
Volvo 7.4TAMD
Queens Cove Marina
Ramsport47
Been thanked: 59 times
Postby Ramsport47 » April 24th, 2016, 6:52 am
Simple answer...No, it is not necessary to run the AC all summer. Fiberglass doesn't really care if it is hot or not. AC is (or was) an option, so, those that never had it, never had any issues with their fiberglass.
Kenny
T-Merc 350 Mag MPI (300hp)
Been thanked: 601 times
Postby tomschauer » April 24th, 2016, 11:40 pm
I agree with all above, your boat does not need to be air conditioned, it is for personal comfort only. A/C compressors, reversing valves etc. have a limited life of xxxx running hours. I personally wish those hours to be while I am on the boat.
CYO Admin
CYO Administrator
CYO Administrator
Has thanked: 269 times
Been thanked: 27 times
Postby CYO Admin » April 25th, 2016, 7:28 am
In addition, the though of a failure some where in the system while I was away all week scares me a bit.
