1986 Carver 2757
- Gary Guy
- Vessel Info: 1986 Carver Montego 2757
1986 Carver 2757
I am in the process of purchasing a 1986 27' Montego aft cabin with twin Mercruiser 4.3L, 4 cyl 190hp engines. I would be grateful for any member comments, whether positive or negative as to the boat and/or engines. It will be surveyed by Feb 15, 2025.
Thanks, and Happy NY!
Gary Guy
Re: 1986 Carver 2757
I'm sure the surveyor will check the common structural areas like decks, stringers, transom, etc. but some don't get into major mechanical components like the engines, drives, transom assemblies. If your surveyor doesn't inspect the mechanical stuff, get a mechanic to look at them or it might cost you big bucks later.
Good luck and keep us posted.
- RGrew176
- Has thanked: 72 times
- Been thanked: 470 times
- Been thanked: 490 times
4.3 is a V6.
The problem is these engines were only made for a few years. Parts are very hard to find and very expensive when needed. Many parts are only used with these engines.
If the boat is solid and the engines are bad, replace them with 4.3's.
- Gary Guy
- Gary Guy
- Gary Guy
- Gary Guy
P.S. Viper- You are correct on the cabin location. It is mid-cabin, not aft-cabin. Listing stated it was aft.
