Replacement Mooring Chain for a 1999 445
- Alastair MacGregor
- Vessel Info: "BAD MONKEY'
1999 445
Cummins
Safe Harbor Ventura Isle
Ventura, CA - Location: Ventura Harbor, CA
- Has thanked: 17 times
Ran out my chain and found it to only be 175 feet long. Last few owners didn't do much with the boat. Wanting to replace with 300'. The current chain appears to be 8mm 1.5" links stamped LH. Local shop wasn't sure of the origin suspects its a foreign make.
Any recommendations for replacement that will be compatible on my windlass?
Re: Replacement Mooring Chain for a 1999 445
- KyleR
- Vessel Info: MV Verity
2002 Carver 396
- Has thanked: 153 times
- Been thanked: 138 times
Do you know the model of your windlass? There are several varieties of chain (e.g. some for mooring, some with longer links, some with shorter links, some designed for windlasses) so do your due diligence before purchasing.
Good luck!
Kyle
2002 Carver 396
1999 445
Cummins
Users browsing this forum: No registered users and 54 guests
