Engine oil choice
Journey!
Vessel Info: 1993 Carver 370 Aft. Crusader 454’s. Lake Superior vessel.
Re: Engine oil choice
Postby Journey! » January 26th, 2025, 1:56 pm
My 1993 Crusader 454’s owner’s engine manual recommends a straight weight 40W oil. I use Rotella. Anyone else?
Has thanked: 598 times
Been thanked: 1281 times
Postby bud37 » January 26th, 2025, 4:19 pm
Welcome to the forum.....how many hours on your engines ?
Has thanked: 78 times
Been thanked: 1093 times
Postby km1125 » January 27th, 2025, 1:08 pm
Using a multi-viscosity isn't going to matter. It won't get cold enough while you're using the boat for the "W" rating to be effective, nor necessary.
Been thanked: 246 times
Postby mjk1040 » January 29th, 2025, 5:23 pm
Rotella 40W is all I ever used in our Crusaders! :beergood:
Has thanked: 64 times
Been thanked: 481 times
Postby waybomb » January 30th, 2025, 12:37 pm
I run Rotella but also add a can of the old GM EOC. It's very high in zddp.
I wiped the cams in the Cougar years ago when they started changing oil so it would not clog catalytic converters. They removed the zinc. I was running flat solid lifters. Wiped all the engines' cams. I bought a bunch of the original EOS and have a lot left over, so I use it in these old Crusaders.
