Purging Fresh Water Holding Tank
- MCADRG
- Vessel Info: 1991 3608 Aft Cabin
Twin 454 Crusaders Gas - Location: Sarnia, Ontario
- Has thanked: 1 time
- Been thanked: 2 times
Re: Purging Fresh Water Holding Tank
Fresh water pumps have a limited duty cycle so don't run it continuously long enough to empty your tank. Run it for about 10 minutes then let it rest for a while. This will prolong your pump's life. Once you empty the tank of the fresh water to rinse the tank and system, you could switch over to dockside water and continue rinsing the hot water side as it will take longer to rinse the hot water tank if it wasn't by-passed for this process.
- MCADRG
- MCADRG
Why don't you want to run the solution throughout the entire system?
- Cooler
- Has thanked: 68 times
- Been thanked: 413 times
- MCADRG
