Bilge pump switch lights always on?
Carverlvr2
- Been thanked: 22 times
This can’t be right, right? Shouldn’t they only light up when activated or with the dimmer up?
- Has thanked: 64 times
- Been thanked: 481 times
Re: Bilge pump switch lights always on?
Or the switch itself has the line connected to the load side and the load connected to the line side.
The switch would still function fine.
- Been thanked: 601 times
Carverlvr2
Carverlvr2
- Has thanked: 598 times
- Been thanked: 1281 times
- Has thanked: 469 times
- Been thanked: 1765 times
Carverlvr2
Maybe trying to correct the very issue you are trying to correct.....by all means check the bilge end, usually bilge pumps/switches are wired in a specific way. Schematics of examples can be found online for the type of pumps you have....good luck man , looks like this next week will be much warmer ...
