Tachometer source of power
- MyPleasure
- Vessel Info: 1992 Carver 36 aft cabin with Volvo 740b engines. Westerbeke 5kw generator. Bought the boat in Portland Oregon in June, and a friend and I brought it up to Sidney, BC. Great trip!
- Has thanked: 2 times
- Been thanked: 23 times
Our 36 Carver has twin Volvo Penta 740B gas engines. My port tach has stopped working over the winter, I checked the connections and everything looks good. Would anyone know if the tachs are driven from the alternator or the distributer?
Thanks for any help
1st Carver 1987 32 Aft Cabin
3rd Carver 1995 350 Voyager
- Been thanked: 490 times
Re: Tachometer source of power
The tech signal comes from the ignition.
Can you get to the backside of the tach easily? If yours are like mine, there is a screw that is used to select between 4, 6, and 8cyl engines. Turn that screw s number of times to all the settings, and then end it in 8. That may fix your issue.
- MyPleasure
I can get to the back of the upper station tachs easily. I swapped the lower port tach to the upper port tach because the upper tach had stopped working, and now that tach has stopped working as well. I’m hoping that it’s not a problem with the wiring to the upper port tach.
When I swapped the tachs, I didn’t notice a setting screw for the number of cylinders, but I’ll have another look.
Thanks again!
- Has thanked: 602 times
- MyPleasure
- MyPleasure
MyPleasure wrote:Source of the post Well, I tried moving the 468 setscrew around and it didn’t make the tach work. I guess that I’ll make sure that it’s getting power from the ignition next.
Follow your wiring under the dash and see if the sync gage has a module that the tach signal is connected to....I guess/assume if the sync works as it is supposed to then there is signal from the engines somehow.
Can you tell what the maker of your gages is ?
- MyPleasure
On mine it goes from the tach to the synch. The synch was not a factory item on mine.
- MyPleasure
