Shurflo waterpump
Pha8
Vessel Info: 2002 Carver 346
Has thanked: 32 times
Been thanked: 5 times
Shurflo waterpump
Postby Pha8 » May 5th, 2025, 5:54 pm
I have a Shurflo 2088-712-244 water pump with a Shurflo water strainer 252-3. When the pump, pumps water, the lid lifts and water spills out the top. I tightened it as much as the lid will go before the plastic piece stops it and still leaks?? The rubber gasket looks to be in good condition. I cannot seem to find a new replacement lid and was wondering if their is a newer model available or if I should just replace the pump with a simular model?
Open flo 3.8 GPM
45psi
12amp max
12vdc
Shurflo 252-3 strainer
Carverlvr2
1979 Searay Sundancer 260
Been thanked: 22 times
Re: Shurflo waterpump
Postby Carverlvr2 » May 5th, 2025, 6:43 pm
I have the 366 version of your boat so I know that plumbing and even have a similar flo jet pump but not sure what the box is for. My forward sink/shower sump is seperate and down lower in the bilge. My fresh water pump is below the galley floor which maybe one of the differences in our layouts. Is that box a sump or part of the fresh water?
Has thanked: 597 times
Been thanked: 1281 times
Postby bud37 » May 5th, 2025, 6:49 pm
Are you saying the lid on the strainer lifts ? Is this freshwater service ?
I have always had a strainer/screen filter on the suction side between the pump and the fresh water tank, that protects the pump from debris.
Carverlvr2
Postby Carverlvr2 » May 5th, 2025, 6:59 pm
Ok, I see now. That white box IS your strainer! As you see in my pix, my strainer is much smaller and directly attached to the pump. Seems yours is maybe easily replaceable with something more compact and would solve your whole issue?
Has thanked: 467 times
Been thanked: 1763 times
Postby Viper » May 5th, 2025, 7:00 pm
If you're talking about the strainer leaking, I'd replace it with the newer style. They're readily available at most marine supply retailers or on line.
Pha8
Postby Pha8 » May 5th, 2025, 7:42 pm
Carverlvr2 wrote:Source of the post Ok, I see now. That white box IS your strainer! As you see in my pix, my strainer is much smaller and directly attached to the pump. Seems yours is maybe easily replaceable with something more compact and would solve your whole issue?
Yes, that white box is the strainer. I am looking to replace it, just not sure what the correct replacement is?
Pha8
Postby Pha8 » May 5th, 2025, 7:44 pm
bud37 wrote:Source of the post Are you saying the lid on the strainer lifts ? Is this freshwater service ?
Yes it is for my fresh water system. One of the tabs are broken so the water pressure pushes the lid up.
Been thanked: 1179 times
Postby Midnightsun » May 6th, 2025, 6:45 am
Must say that is an odd installation for sure. It is very rare a filter of that type is installed on the pressure side so I am thinking this is not original. Just the size of the cover makes it unsuitable for pressure side installation being the surface area translates to a powerful piston like reaction forcing it apart. I would do as others have mentioned and shown, install one on the suction side.
Postby Viper » May 6th, 2025, 7:01 am
Agreed, the strainer must be on the suction side, in the line coming from the tank to the pump.
Pha8
Postby Pha8 » May 6th, 2025, 10:44 pm
Viper wrote:Source of the post Agreed, the strainer must be on the suction side, in the line coming from the tank to the pump.
It is on the suction side before the pump. A new replacement strainer should be ready to be picked up and installed tomorrow.
Users browsing this forum: waybomb and 133 guests
