Shurflo waterpump
Re: Shurflo waterpump
Postby Midnightsun » May 7th, 2025, 5:40 am
I am confused. You say when the pump activates the lid gets forced open and leaks. If it is on the suction side it would not be forced open but rather sucked closed.
Pha8
Vessel Info: 2002 Carver 346
Has thanked: 32 times
Been thanked: 5 times
Postby Pha8 » May 8th, 2025, 4:42 pm
Midnightsun wrote:Source of the post I am confused. You say when the pump activates the lid gets forced open and leaks. If it is on the suction side it would not be forced open but rather sucked closed.
The strainer is attached to the inlet of the water pump.
>The suction/pull side.
Pha8
Postby Pha8 » May 8th, 2025, 4:59 pm
Pha8 wrote:Source of the post I have a Shurflo <a href="tel:2088-712-244">2088-712-244</a> water pump with a Shurflo water strainer 252-3. When the pump, pumps water, the lid lifts and water spills out the top. I tightened it as much as the lid will go before the plastic piece stops it and still leaks?? The rubber gasket looks to be in good condition. I cannot seem to find a new replacement lid and was wondering if their is a newer model available or if I should just replace the pump with a simular model?
Open flo 3.8 GPM
45psi
12amp max
12vdc
Shurflo 252-3 strainer
Sooooo the replacement strainer will not work because it has a barbed end on one side and the wrong size diameter female fitting on the inlet side. I do not want to add any more fittings or connections, so I would much rather just replace the pump and strainer to a newer style with a more universal connection type. Any suggestions on brands and comparable models to what is currently in place?
Postby Midnightsun » May 8th, 2025, 7:06 pm
I completely understand that however how does one explain it gets pressurized when it is on the suction side which is why I am confused.
There are several pumps out there and you will get many recommendations. Shurflo and Jabsco are the big names however I have had very good luck with this one. https://www.etrailer.com/RV-Water-Pump/ ... E57FR.html
Pha8
Postby Pha8 » June 11th, 2025, 10:00 pm
Ended up just replacing the pump and strainer with the Jabsco HD4. Came with a strainer. A little bit quieter and a bit more consistant water presure. PITA to change, but well worth it.
Users browsing this forum: No registered users and 58 guests
