Head maintenance
wbriese76
Vessel Info: 85 carver mariner 28
Head maintenance
Postby wbriese76 » May 21st, 2025, 12:25 pm
The head seems to be original. Looks like 1985 with a full handle pump. I am having problems with the water going down slowly but pumping pulls water in just fine. I can't seem to locate a valve to make the hand lever pump switch to push the water into the tank. What's the deal? Is it blocked or am I blind?
Been thanked: 490 times
Re: Head maintenance
Postby waybomb » May 21st, 2025, 1:28 pm
Welcome aboard!
I'm guessing you have a blockage. You mght just go ahead and rebuild it while you take it apart.
Our first boat had a manual pump and I converted it to electric. But that was 40 years ago.
Postby Viper » May 21st, 2025, 2:14 pm
Welcome aboard. Posting the make and model, or a picture of the unit would help.
Been thanked: 1112 times
Postby km1125 » May 22nd, 2025, 11:06 am
Yea, definitely post up some model info or pics.
Some have a valve that will allow you to pump water in while pumping out, but then stop water pumping in while you pump it out. On some they have a "joker" valve or flapper on the output to the tank that may be damaged which will cause the pump-out to be slower than normal.
Postby tomschauer » May 22nd, 2025, 9:18 pm
Something else to verify is your 28 mariner most likely has a very small waste tank, only good for 10 - 20 flushes. I may be full.
