Looking for Anthracite paint code for 2018 C43 Coupe
Fstone677
Vessel Info: 2018 C43 Coupe
Postby Fstone677 » May 29th, 2025, 11:33 am
I have a few blisters on my hardtop and need to find the paint code for Carver Anthracite for a 2018 C43 Coupe.
Any help would be greatly appreciated!
Re: Looking for Anthracite paint code for 2018 C43 Coupe
Postby bud37 » May 29th, 2025, 2:02 pm
Welcome to the forum......I don't know if this is any real help but I can say that even if ya get the code the color may likely be off a bit and require some correction if you are spot repairing as opposed to repainting the entire unit, then it won't be quite so obvious. Good luck and I hope someone has the code for you.
Is the hardtop a painted finish or is it gel coat finish over glass?
Been thanked: 490 times
Postby waybomb » May 29th, 2025, 8:15 pm
Welcome aboard!
