2007 Carver Mariner Transom Door
Southern Cross
Vessel Info: 2007 Carver Mariner 36’ CDRS8212J607
Postby Southern Cross » June 5th, 2025, 10:12 am
The transom door has a latch built into the rail - a round plastic block with a bolt thumb guide and a pin that slides into a recess in the stbd aft rail. The system was damaged beyond repair and I am looking for a replacement door rail with this slide latch. From the parts list I believe the P/N is 6796108. I could replace with an external bolt or hook latch but would like to find a replacement first. Any source suggestions? Thank You.
Been thanked: 652 times
Re: 2007 Carver Mariner Transom Door
Postby g36 » June 5th, 2025, 12:13 pm
Any chance you could post a picture. This part probably not carver specific.
Southern Cross
Postby Southern Cross » June 7th, 2025, 2:07 pm
Thanks - please see attached. I have tried every hardware company I can think of like Perko, Atwood, Taylor made. Any suggestion would really be appreciated.The rail is closed around the pin. https://www.carveryachtowners.com/downl ... ew&id=8205">download/file.php?mode=view&id=8206.https://www.carveryachtowners.com/downl ... ew&id=8205
Been thanked: 1110 times
Postby km1125 » June 9th, 2025, 8:03 am
Is that the damaged one or just one that looks like it?
If it's the damaged one, it looks like you're just missing the 'button' or handle to operate it. Might be easier to have one of those made that would work.
If that's just one that looks like it, then you might be able to construct one that would work as good, but just a different operation. Perhaps just a stainless tube slightly larger than the rail tubing that would slide over one part completely, but could be slide over the other part when aligned.
You might try contacting the marine salvage yards around Florida or the east coast periodically to see if they get a Carver in. Check around to see what other Carver models might have used the same design too... perhaps several years and several models around your vintage utilized the same design.
Been thanked: 489 times
Postby waybomb » June 9th, 2025, 8:54 am
Not the best/cheapest option but looks simple enough for a machine shop to replicate.
Been thanked: 1309 times
Postby bud37 » June 9th, 2025, 9:40 am
Here is another view/opinion.....You could just abandon that closure and install a nice stainless latch system like the previous models on the door inside surface.....check some online pics from sale ads for lets say a 2001 mariner or years around there that did not have that railing on the top, just the padding.
Southern Cross
Postby Southern Cross » June 10th, 2025, 4:44 pm
Thank You Both, Today, I initiated a possible plan with a machine shop and I agree we could end up with a stainless external latch. I did just launch an inquiry to Southco in hopes.
Southern Cross
Postby Southern Cross » June 10th, 2025, 4:51 pm
PS - Any idea how or why I was honored with the “Scurvy Dog” moniker -)?
Postby bud37 » June 10th, 2025, 8:02 pm
Southern Cross wrote:PS - Any idea how or why I was honored with the “Scurvy Dog” moniker -)?
Tis an honour indeed till thee reaches the next level of posts.......harrrrrgh.... :beergood:
Postby Viper » June 10th, 2025, 9:23 pm
Seeing as you're in FL, have you tried The Marine Connection Liquidators in Fort Pierce or Don's Marine Salvage in Clearwater? They both have a ton of salvaged railings and rail hardware, you never know!!
Users browsing this forum: No registered users and 101 guests
