Screen repair under moon roof
tgherzog
Has thanked: 3 times
Been thanked: 5 times
Postby tgherzog » May 21st, 2023, 1:30 pm
Have a 2016 C37. The screen under the moon roof (is that what it's called?) in the main salon has come loose from its tracks. Any suggestions on how to fix this or get replacement parts? How hard is it to remove the headliner if necessary? Thanks.
tgherzog
Re: Screen repair under moon roof
Postby tgherzog » May 24th, 2023, 12:17 pm
I found the answer to my question which I'm posting in case anyone else has the same issue. The screen is manufactured by Poseidon Interiors. They told me I had to remove the unit and send it to them for repairs :(
tgherzog
Postby tgherzog » November 20th, 2023, 7:46 pm
Update: I removed the skyscreen and it turns out there are 4 small "cleats" that tension each of the four suspension wires. They are in the length-wise track behind the fabric a few inches in from each corner. You can adjust them with an allen wrench. Had i known that I might not have needed to remove the skyscreen to fix it, but at least I figured it out before sending it to the OEM for a very expensive repair!
Postby Midnightsun » November 21st, 2023, 3:01 am
Many items which they claim must be sent in are very repairable if one takes the time to study the assembly and is careful. Be meticulous and patient then most likely you will succeed. There are those out there that will destroy anything they touch though where sending it in is the best alternative. Good info, thanks for posting
rgp987
Vessel Info: 2017 Carver C37
Postby rgp987 » January 16th, 2025, 10:40 am
How did you remove the headliner? Have a 2017 C37 and need to remove skyscreen assembly.
Holt
Postby Holt » June 11th, 2025, 1:43 pm
Hello - I need to remove the interior "paper" folding sunshade in my 2017 C37. Are there instructions to be found to do so? The "thread" has broken and now the screen jams as it opens and closes crookedly.
Sgranier
Vessel Info: 2017 C37, Volvo Penta D4 300 EVC 3.7L Inboards, shafts
Postby Sgranier » August 17th, 2025, 3:55 pm
Hi Holt, did you manage to remove/replace the paper folding sunshade? I also have a 2017 C37 and have to replace mine. (It’s coming unclipped at the stern end and starting to rip.)
Also has anyone had Poseidon Interiors fix theirs?
Sebastien
“Mona Lisa” 2017 C37, Volvo Penta D4 inboards, shafts
Users browsing this forum: No registered users and 47 guests
