A/C circuit only works on Shorepower
- AC3207
- Vessel Info: 1986 3207 Aft Cabin
Re: A/C circuit only works on Shorepower
Do you have a manual shore/generator switch? You probably should inspect the wiring on that (with power disconnected!) to see if there's anything wrong, like loose or corroded connections.
- AC3207
What do you use to switch from generator power to shore power? Is it automatic or do you have some kind of manual switch?
I don't know that generator model, but several models will have their main breaker in a different spot than the controls. I just quickly looked at a manual for that genset online and don't see any indications of it having a breaker on the generator.
If the generator is still supplying power to circuit #1 while circuit #2 is out, then it wouldn't be a main breaker on the generator. The problem would be wherever you switch from shore power to genset power. That could be a manual switch or it could be some automatic relays.
- AC3207
- Has thanked: 602 times
AC3207 wrote:Source of the post Its an automatic transfer. There is no manual switch or device. If the gen comes on it takes over if on shore power.
I don't think you have said but does the generator power up anything at all now ?
If it is automatic then there should/may be a transfer switch, when the generator was powering up both sides #1 and #2 did you hear a clicking sound when the generator was taking over that you don't hear now ?
- AC3207
AC3207 wrote:Source of the post Yes the gen powers circuit 1 fine. It just doesnt show any voltage on circuit 2 nor does anything power up on circuit 2. Everything works on shore power.
I believe there has to be something that isolates the boat when the gen is on and connected to shore IMO.
- buster53
- Has thanked: 10 times
- Been thanked: 285 times
I believe the OP has the genset with an auto-transfer function. I did see some wiring info in the manual about that, but not enough info on exactly where the relays were located. There should be two sets of relays - one for "Circuit 1" and one for "Circuit 2" (similar to how the 356 is setup). I'd bet the one relay for "Circuit 2" has burned contacts.
