2000 Carver 506 - AFT carpet soaked
- KuyaJunGarage
Family and I finally took the carver out, Cummins worked flawlessly, open her up to 2400rpm and 17-18 knots..
for the love of me i can't seem to find where the water is coming from, i think it has something to do when i turn the AC on, it gets wet near the corner Port side Aft.
Wondering if any other 506 owners had this issue? Clogged condesation AC line?
Thanks All in Advance
- buster53
- Has thanked: 10 times
- Been thanked: 284 times
Re: 2000 Carver 506 - AFT carpet soaked
- KuyaJunGarage
I don't see an access panel for the rear sump pump accessible like the front.
Is the only way the opening in the above picture of my 1st post and reach from the side?
Five months in owning this boat I'm figuring everything out. I keep second questioning my decision of buying the boat, but its a 25 year old boat, its to be expected.
thanks
KJ
- buster53
- buster53
Also, where is your AC unit? I’m guessing underneath the bed.
- Has thanked: 598 times
- Been thanked: 1281 times
I would peel the carpet back , dry everything then put down some paper towels here and there, monitor to verify where the water is actually coming from as you run the engines with the hatch open.......try it at the dock first....then you can cross them off the list.
- geo
- Vessel Info: 1988 3297 Mariner
- Has thanked: 4 times
Carverlvr2
- Been thanked: 22 times
- KuyaJunGarage
holy molly you are too in VA! I'm at Belmont bay Marina (occoquan), you?
Bud37 - thanks for the reply. When i took the boat home from Baltimore 17 hour trip, i recall that carpet area was a little wet figured had a screw from the swim platform needing to be re-caulked. But now i'm noticing since i have been running the AC its gets wet.
Good idea next time i'm at the boat i'm going to peel the carpet back and place newspaper and see where its coming from. I took the mattress off thinking it was coming from under the bed but it was bone dry there.
Geo - thanks for the reply - that was the first placed I took apart that part is bone dry.
Carverlvr2 - Thanks for the reply, these old boats! but i done want monthly payments! Yes being 20+ years i'm afraid some pex fittings are going.
I'm hoping its a clogged condensation line and when i fix my sump pump this goes away.
thank you all and appreciate you guys chiming in.
- geo
Users browsing this forum: Bing [Bot] and 31 guests
