Salon AC does not have cold air
- tgebler
- Vessel Info: 2000 396 AC
- Has thanked: 5 times
- Been thanked: 23 times
- Been thanked: 646 times
Re: Salon AC does not have cold air
- buster53
- Has thanked: 10 times
- Been thanked: 284 times
g36 has a good suggestion, turn up the temp enough to kick it into heat mode? What happens? Can you hear the compressor kick in? After a minute or two, are you getting heat?
- Been thanked: 601 times
- Has thanked: 469 times
- Been thanked: 1765 times
- buster53
g36 wrote:Source of the post Not much to go on . What manufacturer of unit? Do all 3 run off the same water circulating pump? Or does it have its own? Is it icing up? Have you tried seeing if there's a high pressure cutout that may be tripped? Try starting the unit and let it run then carefully touch the outside of compressor see if its getting hot or just stays room temp. Tried running in heat mode?
Any progress on your problem?
- tgebler
Users browsing this forum: km1125 and 12 guests
