Kohler Generator Voltage Irregularity
- tim.lesage@twc.com
- Vessel Info: 2001 Carver 570 Voyager
- Has thanked: 597 times
- Been thanked: 1281 times
Re: Kohler Generator Voltage Irregularity
- Has thanked: 76 times
- Been thanked: 1090 times
YIKES!! That would piss me off if they did that much work and really had no clue that it would or wouldn't solve the problem!!
tim.lesage@twc.com wrote:Source of the post
... and they now think it is insulation on the windings, which would be very expensive to deal with. ...
I cannot fathom a failure mode on the windings that would cause that kind of an issue.
bud37 wrote:Sorry I can't say with any certainty , but I do understand engine speed governors....have any of them just checked the governor control on start up, if it is a spring type is may just be getting weak. Anyhow maybe a question to put forward as engine rpm control is necessary for stable operation of those things.
There is at least one model of genset (I can't recall which) that uses an oil-filled governor. That oil is supposed to be changed periodically and if it's not then the governor is slow to react and will not compensate properly.
- ck36
- Vessel Info: 2002 Carver 450 Voyager, TAMD74P
- Has thanked: 13 times
He said voltage fluctuation is normal when generator is seeking out its load.
I assume you’re seeing this behavior when starting the generator under no load?
The sellers mechanic also mentioned that trusting the voltage needle that is on the panel may not be possible as it is a low quality indicator.
Perhaps, but if it’s behaving consistently, it’s probably still an accurate indicator. For $4000 I would think the previous mechanics would have verified that the voltmeter was working correctly?
HVAC) kick in if settles out and no longer fluctuates. It even
stays constant af that point if I turn off the load. I ordered a new voltage meter myself to try that out - should
have that by the end of the week.
Users browsing this forum: No registered users and 50 guests
