Carver 346 fuel transfer
- Pha8
- Vessel Info: 2002 Carver 346
- Has thanked: 32 times
- Been thanked: 5 times
Is their a way to transfer fuel from the STBD tank to the Port tank? Not seeing any switches or pumps?
Cheers
- Has thanked: 597 times
- Been thanked: 1281 times
Re: Carver 346 fuel transfer
Do you have some valves that allow lets say, the port engine to pull fuel from the starboard fuel tank or does each engine just pull from it respective side only ?
- buster53
- Has thanked: 10 times
- Been thanked: 284 times
- Pha8
bud37 wrote:Source of the post If your boat is gas powered then I seriously doubt there will be a pump and hoses factory installed to do that. That was generally a diesel option for safety reasons.
6.2L Mercurisers
Cant see any valves, but maybe something hidden?
- buster53
My fuel switches are mounted on the forward firewall in front of the port engine. Of course, it’s possible you don’t have any at all.
FWIW, I used to have a 3807 and our switches were mounted inside the hanging closet in the aft stateroom. My point…Carver was very creative in where they placed switches, valves, bilge access points, etc. and often, a search had to be made to find things.
- Pha8
buster53 wrote:Source of the post Since our boats are similar…
Yes they are masters at hiding stuff. I will now have to go on an easter egg hunt.
Cheers
- Pha8
Cheers
- Carverlvr2
- Been thanked: 22 times
- Has thanked: 76 times
- Been thanked: 1090 times
Pha8 wrote:Source of the post
Cheers
On the 3607, the fuel selector valves are underneath the lowest step going down into the salon. It hinges up for access to those valves. (the master DC power 1/2/all switch is also there). If someone didn't tell you, you'd have a heck of a time finding those, but crawling around in the engine room and following hoses and cables would give you a clue.
I'd be surprised if a boat as big as a 346 didn't have some type of fuel selection valves, even if just an on/off for each engine.
- Has thanked: 467 times
- Been thanked: 1763 times
You won’t have a transfer pump from factory but who knows what a previous owner might have done. If you do see one, I’d remove it because it’s not uncommon for those to leak. That’s not so bad in a diesel application but very dangerous in a gasoline one.
Users browsing this forum: No registered users and 58 guests
