Need to replace shaft seal
PGMKGT
Postby PGMKGT » July 24th, 2025, 11:16 am
Hello!
I have a 1986 Carver Riviera that needs its shaft seal assembly replaced. Anyone ever have to do this repair and successfully find parts that work? Any help would be greatly appreciated!
Has thanked: 469 times
Been thanked: 1765 times
Re: Need to replace shaft seal
Postby Viper » July 24th, 2025, 8:41 pm
Welcome aboard. Where is she docked? A good prop shop should be able to supply the parts, so should marinas and marine retailers. Why do you need to replace the whole assembly?
Has thanked: 78 times
Been thanked: 1093 times
Postby km1125 » July 24th, 2025, 10:26 pm
I'm wondering what the actual issue is too. That hose can be replaced if it's an issue, as well as the packing. The rest of the parts seem to last forever unless someone's been chewing them up using pipe wrenches.
