1995 Mariner 330 shower drain
- bogrumpus
- Has thanked: 5 times
I plan to get a scope to look further but curious if anyone else has journeyed down this road? I searched the internet and found some info about some models with a sump and some with a float pump. No other obvious access to get under the shower. Anyone??
- buster53
- Has thanked: 10 times
- Been thanked: 284 times
Re: 1995 Mariner 330 shower drain
You need to access the sump box from time to time just to clean it as it can get ugly inside of it.
- bogrumpus
- Been thanked: 1180 times
These boxes are not sealed and if either the pump or limit switch fail, they will overflow into the bilge. They do get filled with soap scum and debris and do require regular cleaning once a year or 2 depending on how often the shower is used
- buster53
bogrumpus wrote:Source of the post That’s what I was hoping, but I think it is unfortunately draining directly into the bilge! Looking down with a pen light, all I can see is fiberglass. I ran the water for a little bit and sure enough the center bilge started to fill. The pump is running, but doesn’t appear to be doing anything so I have no idea where the hoses are connected to. I’m going to run a scope tomorrow to check but I think I’ll have to take the shower pan out and install a new sump and pump. Would love to know its history, but probably never will. Thanks!
You are turning a simple procedure into rocket science. I can almost guarantee you have bilge access ports in the cabin just outside the bathroom door. Pick up the carpet and look. All your hoses and probably your sump pump box will be inside one of those ports. Also, FWIW, Carver is well known for putting access ports in out of the way, out of sight places. Get a good flashlight and go hunting. I’ve had my 356 for 7 years and I just found a couple access ports a few weeks ago I had no idea they were there.
- buster53
- bogrumpus
- bogrumpus
- buster53
I assume you have an AC unit. Where does the condensation drain to? It should be draining to a sump pump. I'm guessing it is just going into the bilge, but worth checking out.
- bogrumpus
