Data link connector location
Punch'Eau
Vessel Info: 2000 350 Mariner
Has thanked: 25 times
Been thanked: 7 times
Postby Punch'Eau » July 28th, 2025, 10:30 pm
Hi, I have the chance to use a Mercruiser computer to check one of my engines for a few days but I can't locate the right connector on the engine. The only connector I found is near the distributor and it doesn't match the Mercruiser connector.
first photo is the Mercruiser adaptor and 2nd and 3rd are from my engine
I own a 2000 350 Mariner with 7.4 mpi
Thanks in advance for any help.
Re: Data link connector location
Postby Viper » July 29th, 2025, 6:50 am
You have the wrong adaptor for that vintage engine.
Postby Midnightsun » July 29th, 2025, 7:38 am
To add to Vipers post.
Pretty sure the purple stuff is for Smartcraft equipped engines. Your connector says you do not have smartcraft and need another type of connector.
Postby bud37 » July 29th, 2025, 8:02 am
Welcome to the forum......google rinda diacom tecnologies 94005 GM mefi 1-4 adaptor......that may be the correct one, check it out....needs pins.
To add, by the look of the tape to me, someone has been in there perhaps.
Punch'Eau
Postby Punch'Eau » July 29th, 2025, 9:08 am
Thanks to all. That s the doubt I had. I will check with the dealer who lent me the computer.
Thanks again
kgarguilo
Vessel Info: 1999 Carver 406
Has thanked: 197 times
Been thanked: 55 times
Postby kgarguilo » August 3rd, 2025, 2:40 pm
Just a thought here... I purchased the Rinda software https://www.rinda.com/marine/diacommarine.htm and the diagnostic connector for my 454's and look at it when trouble comes up. But I also put in the Fox Marine Mefi 3 Engine gateways https://fox-marine.com/index.php?route=product/category&path=81 that are on my NEMA 2000 network, and the data shows up on my Engines tab on my Garmin 8612. The gateways are not that much $$, and it displays quite a bit of data on Mefi 3. They also have a phone app you can access the data on your phone via Bluetooth. Just food for thought.
Kevin G.
1999 Carver 406
Punch'Eau
Postby Punch'Eau » August 27th, 2025, 9:33 pm
bud37 wrote:Source of the post Welcome to the forum......google rinda diacom tecnologies 94005 GM mefi 1-4 adaptor......that may be the correct one, check it out....needs pins.
I googled but all the adapters related to MEFI-1 to 4 are ok for my engine connector but at the other end they have a round one :banghead:
Postby bud37 » August 27th, 2025, 10:21 pm
Here is a link to some info.....
Punch'Eau
Postby Punch'Eau » August 27th, 2025, 11:03 pm
bud37 wrote:Source of the post Here is a link to some info.....
Thank you. It gives no choice to buy Diacom adapter and cable "gateway". I found this (see photo). It is really the one I need. Had to search a loooot.
Thanks again
Postby bud37 » August 28th, 2025, 10:22 am
Good stuff....Thats the trouble, they all seem to trap you into getting their line of overpriced adapters don't they, different connecters to do the exactly the same job imo .... ;-)
The one thing about rinda, they have quite a history with gm ecm interfaces etc.
Thanks for posting the find , I am sure that will help someone else in the same bind. Good luck with your diagnostics.
