57 Voyager, shower won't drain
- Barrett50
- Vessel Info: 2006 Voyager Pilothouse 57
- Been thanked: 4 times
Section two discusses the sump pump, and operation with a 'breaker' to enable:
2.2.1.2 Auto Sump - Forward and Aft
This breaker controls the flow of electricity to the forward and aft sump
pumps. Because the sumps are located below the boat’s water line, the
sump pumps are needed to pump shower waste water, sink waste water
and air conditioning condensation overboard or into the optional grey
water tank. Each sump pump is activated automatically by a float switch
whenever water within the sump rises above a predetermined level.
Switch the Auto Sump - Forward circuit breaker “ON” before using the
air conditioning or showers and sinks in the port and starboard heads.
Switch the Auto Sump - Aft circuit breaker “ON” before using the optional
crew quarters’ air conditioning, shower or sink.
Well, I don't have a 'auto sump' breaker anywhere on my DC panel either. I know the drain for the sinks is working as they drain well. When it was surveyed, I don't think they ran the shower enough to have the auto float switch. Which leads to these questions:
1. Does anyone know where this sump pump breaker is supposed to be on the DC panel? I don't have it listed.
2. Does anyone know where the tank and pump and switch are located in the engine bay so it can be tested/fixed?
3. I KNOW not to use a plunger on the vacu-flush as it will invert the flapper of the valve. Can I use a plunger on the shower drain in case there's a blockage?
The hall way bathroom sink seems to drain just fine. I would presume they go to the same tank, so I'm fairly sure I have a blockage in the shower to tank section. Any assist would be appreciated.
- Been thanked: 1180 times
Re: 57 Voyager, shower won't drain
Sinks may or may not empty into the shower sump as some go directly overboard such as my galley sink.
You say the shower does not drain? Does it still drain slowly or not at all? If it drains slowly then the float switch and/or the pump in the shower sump probably needs replacing. You need to find your shower sumps, usually located under carpeting via a hatch for servicing not too far from the shower. These sumps need regular annual or biannually servicing as they do tend to crud up therefor the importance of locating them. For what it's worth, I do both of mine every fall layup and no problems all season long.
- buster53
- Has thanked: 10 times
- Been thanked: 284 times
Your sump pumps are physically near your drains, probably within a couple of feet and as mentioned, they need to be cleaned out at least once a year, more if you use your showers a lot. FYI, the sump is basically a plastic box, maybe 8" x 10" with a bilge pump inside. Water from showers, air conditioning condensation and sometimes sinks drain into the sump, bilge pump kicks on and pumps the water overboard.
- Has thanked: 469 times
- Been thanked: 1765 times
Breakers for bilge pumps and sumps may be a different type than the toggles for the other systems, and they're not always labeled. You may have button type push/resettable breakers instead. The button pops out/up when they trip so look for that. They use those so you can't accidently shut your bilge pumps off but are still able to protect the circuit. These circuits may not be in your main distribution panel either, they could be on a junction box in the engine bay, under a step, aft stateroom closet, anywhere really. If you have battery selector switches, look around there, common for them to be in the same spot.
You need to find this sump and it's breaker. If the pump is seized and the breaker hasn't tripped, the pump will heat up and could cause a fire. Hopefully it's just a stuck float switch or clogged drain but you need to address this asap in case it's an electrical issue.
Hopefully someone with a similar vintage 57 will chime in. Keep us posted.
- KyleR
- Vessel Info: MV Verity
2002 Carver 396
- Has thanked: 143 times
- Been thanked: 134 times
Kyle
2002 Carver 396
- buster53
KyleR wrote:Source of the post On my 396, there is a "DC Safety Panel" (Carver's terminology) that is located in the master (aft) stateroom. It has the bilge pumps, the sump pumps, and other DC equipment that Carver thought should be isolated from the main DC panel. Try to see if you have something similar and you might find those sump pump breakers - and some other important ones too.![]()
Kyle
On my 356, I have the same setup. Lift up one of the steps leading down into the salon, I have at least a 1/2 dozen breakers as well as my battery 1-2-Both-Off switch.
Also, up on the flybridge, underneath the bench seat forward of the helm, there is another series of breakers.
- Barrett50
- buster53
- ck36
- Vessel Info: 2002 Carver 450 Voyager, TAMD74P
- Has thanked: 14 times
- Been thanked: 2 times
- Has thanked: 598 times
- Been thanked: 1281 times
ck36 wrote:Source of the post Sorry, but I can't post photos on this board yet
You should be able to post pics, just use the add files button below the post box.
