2000 Carver 506 - AFT carpet soaked
KuyaJunGarage
Vessel Info: 2000 Carver 506
Re: 2000 Carver 506 - AFT carpet soaked
Postby KuyaJunGarage » July 30th, 2025, 1:15 pm
Update...well after this weekend which it didn't rain, my carpet got soaked again.
Back to square 1.
AC was running all weekend and the city water was connected . I think its a combination of all of the above recaulking/grey tank pump etc.
Since weather is looking good this weekend 80's. Will tackle the grey tank pump.
will keep you guys posted.
trwestman
Vessel Info: 2002 Carver 506
Configured as a Soft-Top Bridge with Glass Aft-Deck
Cummins 450C (480hp) ~725 hours
Has thanked: 16 times
Been thanked: 7 times
Postby trwestman » July 30th, 2025, 1:58 pm
Isn’t the grey tank line below the floor?
I’d be pulling the access box off to look at all connections while still connected. It’s a job but you have rule out those three different connections. Good luck.
Tom
2002 506
Postby bud37 » July 30th, 2025, 2:19 pm
The leak source can actually be quite some distance from there so be systematic tracing back, maybe tape up some dry paper towels here and there behind panels and see which ones get wet , maybe from that get a direction of travel....good luck man.
KuyaJunGarage
Postby KuyaJunGarage » August 27th, 2025, 10:37 am
Alright I think i have found a solution with my grey tank. Since i can't get to the pump screw to dettach the hose from it. I'm going to cut a new access hole. what you guys think?
new access panel is 10" wide
RambleOn506
Has thanked: 2 times
Been thanked: 2 times
Postby RambleOn506 » October 22nd, 2025, 9:46 pm
I had to do this to the forward gray water tank this summer. Lost the pump and cut a new much larger hole in the top of the tank. Here's a before...
KuyaJunGarage
Postby KuyaJunGarage » October 29th, 2025, 10:49 am
RambleOn506, thanks for the reply, Yep, i finished this project and couldn't be any happier! this one was a win!
