454 crusaders rpm drop from neutral to fwd
- sbb2112
- Vessel Info: 1982 Carver Monterey 2687
260 Mercruiser / Mercruiser Alpha sterndrive
1992 Carver 350 ACMY
454 Crusaders with V-drives - Location: Michigan
- Has thanked: 2 times
- Been thanked: 10 times
- Been thanked: 1112 times
Re: 454 crusaders rpm drop from neutral to fwd
- Has thanked: 602 times
Set the engine to spec in gear if you are having issues.
- sbb2112
- Been thanked: 490 times
I happen to have an 80-92 Crusader Service Manual and here's the spec sheets. Idle for all is 650-700 in gear. And 10 btdc. But it did remind me that if you have the E.S.T ignition make sure you turn the connector around when setting base timing.
- sbb2112
sbb2112 wrote:Source of the post Thanks all for the info. I am going to set to the specs shown for the delco ignition. Pretty sure raising the idle will make a big improvement.
I agree, a couple degrees is almost impossible to get right on an older engine anyway.
One other thing to be aware of can be the idle mixtures on the carbs, be sure they are not too lean. Many times folk will go for the best lean idle which I have found sometimes doesn't work well for me in any carbed boats we have had, slightly rich is a bit better at maintaining idle quality in gear/under some load.
