2000 Carver 404 - All Batteries and DC Equipment Dead - Suspect Battery Charger?
Reardon
Topic author - Scurvy Dog
- Vessel Info: Carver 404 2000
Picked my 2000 Carver 404 from her winter storage, Started up fine, took her to her home slip 5 miles away and plugged in the shore power on Friday.
This morning, no power to any of the DC equipment. All batteries dead (2 engine/house and 1 generator).
When the shore power is plugged in, both AC panels show power (Volts and amps) and the equipment on those circuits all seem to have power (AC, micro, etc.) and work But, none of the DC equipment works, batteries are dead.
I am suspecting a battery charger issue. Especially after I read some of the reviews for my charger (not so positive). I have tried to check out all the obvious stuff like main breakers, safety panel breakers, etc that might be switched to off, but all seems in order.
Any thoughts would be appreciated?
Rich
docbob3704
- Vessel Info: 2002 350 Mariner with 3.5 Volvo pentas. Lake Erie, Niagara River, Buffalo NY
1st Carver
Re: 2000 Carver 404 - All Batteries and DC Equipment Dead - Suspect Battery Charger?
- Ramsport47
- Has thanked: 72 times
- Been thanked: 59 times
T-Merc 350 Mag MPI (300hp)
- Has thanked: 469 times
- Been thanked: 1765 times
After you check all the above, a volt meter will tell you if the charger is putting out or not.
Did you run your generator during your trip? A dead generator battery may have nothing to do with what's currently going on as some vessels do not charge the generator battery with the house charger, and leave the generator battery to be charged by the generator when it's running. When it's not running, there should be no load on that battery so if it's good, it should hold a charge. Even if that battery is charged by the house charger, there is no reason for it to discharge due to a charger hook-up issue or breaker trip. A certain circuit failure in the charger will discharge a battery though.
Curious, what was left on from Friday to Sunday morning that would kill your batteries? And why are you leaving the battery selector switch on "ALL"?
- AaHubb
- Vessel Info: '99 404 CPMY
- Has thanked: 15 times
- Been thanked: 61 times
..Aaron
SeaDragon
Reardon
He has new batteries in, but I don't think they are charging (waiting for his report). I am guessing he will then go through some of the items you guys suggested checking output downstream from the charger to see if it is putting anything out, etc.
The batteries initially had the fridge, etc drawing on them when they went dead the first night.
Thanks again
Rich
- Been thanked: 601 times
- bakeefe4
- Vessel Info: 1991 Carver 33' aft cabin
Make sure you didnt miss a ground. Next check at your battery switches and at the main 12v breakers. Did any of this get wet? If you have no 12v in the cabin or at the bridge it is most likley one of the three things i mentioned.
As far as the fridge, it may be a coincidence, or did the control board get wet?
