Battery switch in salon
- RyDrew
- Vessel Info: 2004 360 Mariner
Purchased on October 14, 2025 - Location: CT
- Has thanked: 1 time
- Been thanked: 2 times
Brand new owner of a 2004 360 Mariner, and relative newbie to boating (4 years). Lots of stuff to learn on this boat which is significantly more complicated than my previous four winns 268 vista.
Can someone explain what the "accessory" battery switch in the salon cabinet, to the right of the sliding door? It only has on or off. My previous boat had a similar switch which had 4 positions..... On (to use and charge the starting battery by the alternator) Accessory (to use/charge the house battery) Parallel (to use both batteries to start) and Off.
1. What does this switch control? When should it be on/off.
2. Is there a similar switch like my old boat? (can the House Battery be used to start in an emergency or some other way to start when one batt is dead?
Thanks, and please be patient with me as I learn the boat.
- Has thanked: 603 times
Re: Battery switch in salon
My advice here, it would be wise to go thru all the dc stuff, batteries, switches etc and figure out what controls/powers what on your boat. The reason I say this is previous owners/mechanics can change things around from the oem set up and it can be quite different from what others have, even the exact same boat. Just don't assume.
Our old 350 mariner oem set up was, three batteries, one for each engine, one for the generator , the gen one had an on off switch in the bilge and a 1/2/all/off in that cabinet. It did not stay that way.....
Good luck with your new boat.
- RyDrew
RyDrew wrote:Source of the post Thanks Bud37. Didn't you have a house battery for the ship systems?
In reality you chose which of the two batteries to use or both. Originally, the mercruiser install instructions mention having one battery for each engine requirement due to the ECU , which they sort of ignored.
I altered it all to basically have a 2 battery start bank and a 4x6volt battery house bank. A few others have done the same basic set up, there are always some slight variations to the theme though with extras.
Carverlvr2
- Been thanked: 25 times
- RyDrew
Note: It has the same warning about not switching while engines are running.
Carverlvr2
- RyDrew
Carverlvr2
- RyDrew
And also, I assume it stops the alternator from charging the house battery(s)?
