Fresh water tank
Graham
Vessel Info: 1977 Mariner
Fresh water tank
Post by Graham »
I have a 1977 carver mariner 28 foot and my fresh water tank leaks. can it be repaired or is there a pac to purchase one, or is there a used on available?
Graham
Has thanked: 10 times
Been thanked: 248 times
Re: Fresh water tank
Post by mjk1040 »
:beergood: Not sure where you will find an used one, use to be a salvage yard in GA. If your tank is plastic you can have it welded or try Flex Seal tape maybe, Or just replace it with w new tank! Good Luck!!
Has thanked: 605 times
Been thanked: 1313 times
Graham wrote: May 10th, 2026, 1:55 pm I have a 1977 carver mariner 28 foot and my fresh water tank leaks. can it be repaired or is there a pac to purchase one, or is there a used on available?
Graham
I think you will be better off to just get a new tank made, there are plastic places that can do this kind of work to order, check around your area. This way perhaps a larger tank if it will fit..... :down:
Yes they can be repaired but.....I have tried getting old plastic tanks welded, did not work for splits/cracks around threaded fitting parts. There will always be some doubt down the road with a repaired part especially on old plastic, IMO.
Been thanked: 1117 times
Do you know WHERE it's leaking yet? Could be just one of the fittings cracked over the winter and needs to be replaced.
If you do end up needing a tank, greatlakesskipper has tons of them of various sizes. You likely won't find the exact tank, but if you take measurements of where it has to fit, you could likely find one on that site. You could even go a bit larger or smaller depending on the space. And they're great prices compared to buying a brand new or a custom one to your same dimensions.
Post by g36 »
Here the oem tank manufacturer for Carver. Least it was fir my 405. They will customize it too if you want other changes than oem . Or want to go larger etc.. https://trioniccorp.com/products/holdin ... AMQAvD_BwE
